-   -   Where can i find the 20 degree brake caliper piston alignment tool...?? (http://forums.pelicanparts.com/porsche-911-technical-forum/685983-where-can-i-find-20-degree-brake-caliper-piston-alignment-tool.html)
911 tweaks 06-27-2012 06:39 PM
CAN ANYONE ADVISE WHERE TO GET THIS TOOL AS PELICAN DOES NOT OFFER IT...IF I AM CORRECT = PELICAN DOES NOT CARRY THIS, CAN SOMEONE PLEASE POST UP WHERE TO BUY IT or post an attachment or email me THE EXACT DIMENSIONS/FILE SO I CAN PRINT IT OUT AND USE IT AS A STENCIL TO CUT ONE OUT...THX IN ADVANCE...BOB
mtb001 06-27-2012 06:41 PM
brake tool
take the bentley's manual, a protractor, a piece of thick construction paper, and make it.
mtb001 06-27-2012 06:44 PM
20 deg. caliper alignment template - Rennlist Discussion Forums
911 tweaks 06-27-2012 06:45 PM
ok...I'll check out bentley to see if I can find it...is the shape more than a 20 degree wedge...??
I believe the tool is designed to be able to engage & rotate the caliper piston to correct its alignment if its off, right...??
911 tweaks 06-27-2012 06:46 PM
thx for this speedy help mtb...I cannot access the rennlist site...so, can you post up here on this thread what ever is there that will help me...thx in advance...Bob
TimT 06-27-2012 07:20 PM
make it
Make one....
The dimensions are in my old Bentley, Clymer, Chilton manuals and are described in the factory manuals... and have probably been posted here at some point
timmy2 06-27-2012 07:21 PM
Here ya go.
http://forums.pelicanparts.com/uploa...1340850076.jpg
pete3799 06-27-2012 07:24 PM
+1 make one
http://forums.pelicanparts.com/uploa...1340850217.jpg
boyt911sc 06-27-2012 07:40 PM
20° Template..........Using trigonometry
Draw or make a triangle with equal sides. The corners would have 60° each. Divide the arc into 3 equal parts and connect the corner to the point/s on the arc. Now you have a 20° angle template without using a protractor. Or contact Ed Mitchell (evangene). HTH.
Tony
sailchef 06-27-2012 08:11 PM
If I recall, I eyeballed this 4 years ago and have never had any issues.
vash 06-27-2012 08:32 PM
if you make one..make it out of clear rigid plastic. kinda makes it easy if you can see thru it.
i admit, my last rebuild was on some turbo calipers..it got confusing, so we eyeballed it. brakes are quiet.
Gitano 06-27-2012 08:41 PM
Can't it just be eyeballed? Looking at the caliper diagram above, the bottom edge of the slot on the piston is at the 9 o'clock position. Just line it up by sight and gently push the piston in. The "tool" is not designed to rotate the piston in the caliper. A piece of cardboard will serve to check it, but you can also do it by sight. Just make sure you have the orientation correct relative to the rotation of the rotor.
RWebb 06-27-2012 10:51 PM
No!
It MUST be made out of Ti!
Quicksilver 06-27-2012 10:54 PM
Tin snips and a chunk of sheet metal.
To turn pistons I use a set of heavy duty snap ring pliers used on transmissions.
Quicksilver 06-27-2012 11:07 PM
Easy way to make a 20° triangle...
Cut the corner from a rectangular piece of metal so one side is 2.5" long and the other is 0.9" long. That will give you a more then accurate 20° angle. (19.7989°)
Smoove1010 06-28-2012 06:57 AM
This isn't rocket science - I made mine from some stiff cardboard to match the line drawing above with a protractor, ruler, and a razor blade. You could also print the image and trace it out onto the cardboard. You'll need to gently turn the piston by hand or with pliers to meet the angle of the guage. Worked fine - the car stops almost every time I press the brakes, and no noise...
911 tweaks 06-28-2012 07:02 AM
thx guys...I found out that Ed M. the coupler guy made some of these in the past...I am awaiting to hear back from him to see if he has any more so I can get one...
vash 06-28-2012 07:21 AM
Let me know. I can mail you mine. Clear plastic and cut to a perfect 20. My OCD took over. I can't see a rebuild in my near future.
CCM911 06-28-2012 07:23 AM
+1
I rebuilt all four about seven years ago, and just did a second rebuild on the rears. I just eyeball it and have never had an issue. And Gitano is correct. The photo in the Bentley shows the positioning.
Easy-Peasy.
James Brown 06-28-2012 09:07 AM
the templet is in the instructions for the caliper rebuild kit
