polizei's Avatar
Need Help Removing Short Flexible Oil Hoses from Hard Lines
Guys - I'm in the process of cleaning the front auxiliary oil cooler and lines in my '87 Carrera. I successfully removed the cooler from the Short Flexible Oil Lines but I'm having trouble separate these from the hard lines. I've been spraying with PB blast since the weekend and tapping with a hammer, but the bugger won't budge.
Any recommendations?
I have a new set of Short Flexible Lines, so I'm thinking about cutting them off with a dremel and then using a deem 36mm socket to remove them fully. Thoughts?
Andy - 1987 911 Carrera Coupe
Old 07-17-2012, 02:58 AM
Almost Banned Once
sc_rufctr's Avatar
It may be best to completely remove the hard lines from the car. That way you can clamp them in a vice and then remove the soft lines.
It's not a lot of work but you have to remove the hard lines from the thermostat and the lines could also be stuck there.
Or remove the entire oil line assembly including the soft lines going to the oil tank and engine.
Probably a good idea in the long run. You'll have to opportunity to clean everything 100% before putting everything back.
I personally wouldn't use a Dreeml to cut the lines because I'm paranoid about steel grindings finding their way into the oil lines.
But if you feel confident then go for it.
- Peter
Old 07-17-2012, 03:28 AM
BoxsterGT's Avatar
Porsche Crest
You don't need to dremel thru the nut, just cut deep enough in 2 or 3 places to weaken it. Be careful not to go thru into the threads.
Should be lots of info here on this with photos if you do a search.
Len
Old 07-17-2012, 04:59 AM
Northern Motorhead
wildcat077's Avatar
Andy,
Use lots of heat ... preferably with Mapp gas as it burns a little hotter than propane !
When i separated my two short lines that go to to the cooler i just kept applying heat,then PB Blaster,more heat ... etc ...
Finally came loose without destroying the threads !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-17-2012, 05:00 AM
scotricker's Avatar
You could use two wrenches and a a clamp like this:
It worked for me on the big engine oil line. Just keep on clicking the clamp closed, and the threads will work loose without bending the hard line. first, of course, use all the PB blaster and heat, etc, too.
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 07-17-2012, 05:21 AM
Try heat before anything else, especially since You have new flex lines, and dont need to worry about damage of rubber. Heat will solve your problem. Probably enough with propane. Heat a lot, and then a perfect grip, best with open end spanner and the connections will loosen up without to much violence. Make shore you clean inside of hard lines after.
(and heat only the nut to the right on picture, turn that one and make shore You keep the left one still)
Old 07-17-2012, 05:34 AM
redridge's Avatar
Ive just went through this, I went with the dremel route and all is well. You have to release the tension, so I cut in two places and chiseled out that section that was dremeled (maybe 1/4" chunk). Came out with little effort turn of an adjustable wrench.
The prob with these connection is not so much on how tight the threads are, but the way the inner coupling gets pressed inside the other half of the fitting when they are joined. So heating them will take a long time as getting the pressed coupling is beneath the nut and threaded fitting, so there is a couple of layers the heat has to go through.
Old 07-17-2012, 05:45 AM
polizei's Avatar
Guys - I'm a novice do-it-yourself'r, and I don't even have a torch! Can someone make a recommendation?
Old 07-17-2012, 05:46 AM
redridge's Avatar
Home depot sells kits of map gas...
Old 07-17-2012, 05:47 AM
A small propane torch is cheap. Apply heat to the right nut for a couple of minutes, make shore You have a perfect grip with wrench or spanner, move fast, keep the left fitting still (part of hard line) and turn the right nut. When the nut is loose, keep your wrench on the left fitting and carefully hit the flex line with a hammer, or break it lose by "wiggling" it by hand close to the loose nut, and You Will feel the flex line come lose.
Old 07-17-2012, 05:50 AM
polizei's Avatar
I just bought a Bernzomatic TS4000 Torch from Amazon. I'll try to tackle this bugger on Thursday. Thanks guys!
Old 07-17-2012, 06:07 AM
It's all about technique, torque, and leverage.....
Andy,
You met me the other day, I'm about twice your age, 134 lbs. soak and wet, with a bad back and knee, and yet I've been breaking these oil lines regularly with ease. Like what most people suggested, you need heat application and penetrating oil, leverage (see Scot's version), using the correct tools, and most of all an effective technique or method. While these oil lines connections could be separated while on the car, removing the whole assembly and working on it would be more convenient. Is the car on jack stands or lift?
Due to the extreme weather condition today, I've been advised by my family to stay indoor and stay in the basement and that's what I'm doing now. Since you have removed the two (2) oil lines under the right rear wheel well, auxiliary thermostat, and Carrera cooler, everything except these 2 brass oil lines are remaining (plus 2 short flex lines). Drop them to the floor and you'll find it easy on your back when you have more room and leverage doing this type of job. Try it first with the oil lines in place.
You don't need brute force or strength to overcome these stubborn connections. It's all about technique and a flick of the wrist. Keep us posted.
Tony
Old 07-17-2012, 11:05 AM
polizei's Avatar
Tony - Thank you for the encouragement and direction. I've ordered a torch to help with loosening the nuts and will continue trying.
You're wise to stay inside today. It's days like today that actually make me want to stay at work longer and enjoy the A/C! Thanks again for your help over the weekend.
Old 07-17-2012, 11:47 AM
Registered Lunatic
BTW. . . . . when you put it back together. . . use ridiculous amounts of anti-seize . . .I mean, go plaid with the stuff, just as long as you're not getting any inside the lines.
You may not ever have to take them apart again, but the few $$'s on the anti-seize may help you out in the long run if you ever do.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up!
Old 07-17-2012, 12:01 PM
Andy - I used a Dremel to cut the old nut on my rear oil line. That should work on your's as well. If you are still having problems, let me know and I will stop by on Saturday with my Dremel and a cold chisel. Trust me, those puppies WILL come off! And if Tony and I can do it, then so can you.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
