930 smog pump belt
I'm in the process of replacing the smog pump belt on a 87 930. I've pulled off the intercooler and air box to access the pump. I'm still not sure how to access the lower pulley. Looking at the factory workshop manual, it appears that the oil pump has to be removed to access the cover. I can't believe it's that complicated. Any guidance would be appreciated.
Thanks,
Old 04-27-2006, 10:08 PM
air belt
yes it is that complicated...really its not that bad justnuts and bolts..do it yourself
Old 04-28-2006, 07:47 AM
Cymru am Byth
carmad's Avatar
It's a pain, it runs off the left camshaft. You need to remove part of the housing to be able to get the belt out. I changed the seals while I had it off, you might want to replace them.
Just be methodical.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 04-28-2006, 08:24 AM
resident samsquamch
sand_man's Avatar
What the others have said....
I'm not sure where you are located (emmissions), but now is the time to think about how much this little "band aide" really adds to your Porsche experience - in other words, if you can dump this *****...DO IT! I can post some helpful threads that will guide you in the removal, if you like.
Jeff
-jeff
Old 04-28-2006, 08:35 AM
resident samsquamch
sand_man's Avatar
In addition, before I removed all of the smog equipment on my '87, I ran with the air injection belt disconneted (I cut it) for a couple of months with no troubles.
-jeff
Old 04-28-2006, 08:40 AM
Slant930's Avatar
Smog pump, what is that?
Tim
1983 930 w/ goodies
Old 04-28-2006, 09:58 AM
Red face
Acutally, I'm in the process of re-installing some of the smog equipment California sucks wrt emissions. It's become too much of the PITA smogging this car every other year.
Old 04-28-2006, 10:06 AM
This is the only intallation forum I can find
I know this link is pretty old...I am just wondering, how did you access that lower pully? I am thinking of taking the wheel off and going that way, or from under. Or did you get in there from above, by taken out the intercooler likeyou said? Could use a tip or two.
thanks.
Paco
another California 930 owner
Old 07-01-2012, 07:48 AM
