jamesjedi's Avatar
What Size of Dzus>
Hi,
Propably going to use Dzus fasteners on my rear quarters. I say probably, because it is tempting to just bond them.
What size do I need?
How many per quarter?
Thanks for any help.
Old 07-07-2012, 12:57 PM
Navin Johnson
TimT's Avatar
I used 12 per side on my car, the number you use could be different depending on layout and spacing...
You need to figure out the length of the dzus component to use also.... figure a stack of 20ga steel and 3/32 glass with a bit of space etc..
'69 911 GT-5
'75 914 GT-3
and others
Old 07-07-2012, 02:47 PM
jamesjedi's Avatar
Thanks for the reply.
Have you ever had them come loose?
If you did it again, would you just bond the panel?
Old 07-07-2012, 05:43 PM
Mitch Leland's Avatar
On aircraft we use a Dzus that has a collar that is set with special Dzus tools. The outer piece would only show a bezel and the slotted screw head. This works for aluminum, not sure about installing on F/G? Also you can get Stainless Steel Dzus.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 07-07-2012, 07:41 PM
