Formerly reformed
911 Structural Question
I recall reading an article that insisted the 911 tub (minus exterior sheetmetal such as rockers and quarters) was the sole source of the car's strength and that they can be run without the outer metal. The reason I'm asking is because I still have the tubing matrix in place that supported my car when it was cut in half and I believe it's safe to remove now that the floor, longitudinals, inner rockers, torque tube and rear shelf/seat back area are all permanently in place.
The heel panel and rear seat bottom are the only pieces yet to be installed and the support tubes are really getting in the way. Plus, I'm tired of hitting my head upon entry/egress. Should I keep these in place until the quarters, heel panel et al. are in place or is it safe to assume that the car is as strong as it's going to be? You can see the bars in this pic. Will go shoot a pic of car as it sits if necessary but it will mean moving a sleeping dog.
1968 911P (Paperweight) |
Senior Member
In my humble opinion, the two guys to chat with on this topic are Steve Weiner and Tyson Schmidt. Those two guys know where, and how, a 911 chassis is stiff or flexible, and how to increase rigidity. A 911 chassis is pretty stiff, for a vehicle of its construction and vintage. But it's not completely rigid. Like any car, the surest and most effective way to achieve substantially more rigidity is to weld in a roll cage that connects the front strut towers to each other and to the rear strut towers. Of course. But again, if you're wanting to think outside the box, talk to Steve or Tyson.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Why isn't this in the technical section? Why are you bespoiling our political discussion with this nonsense about cars? Be gone with ye!
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Team California
Tech question, Porsche content, 911 specific...I have seen a good forum for those cars somewhere.
Denis |
Formerly reformed
Yeah, yeah. The SMART people hang out over here, though.
I'm with Bill
Fixed it for ya.
![]() Sorry man that was just way too easy
Electrical problems on a pick-up will do that to a guy- 1990C4S |
The Unsettler
I wanna know why you cut your car in half?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Formerly reformed
There was nothing solid to weld to so I ended up replacing every piece of metal from the floorpan to about 18" up all around. The car had it coming.
AutoBahned
also, call Dave at TRE
in any event, you should stiffen the car while it is all apart -- he has done that and I hear the results were phenomenal -- he might have some parts to sell you to make it easy too |
Senior Member
Stiffening a car does achieve phenomenal results. Whole new ball game.
Formerly reformed
I'm hoping it's strong as it sits- I seam welded the chassis and replaced the old rear 'frame' & longitudinals with new pieces made from 14 ga steel.
And the JB Weld I used on all of this said 'professional strength' . . . so I have that going for me.
AutoBahned
the seam weld is good, but there are some pieces that can be added - I don't know what, exactly but call Dave B., Steve & Tyson - that is a pretty high level brain trust
- don't make the mistakes I made - do it all up now instead of thinking about how you wish you had known what could be done... |
You do not have permissi
Should be in tech, where all the really really smart guys are.
More big pics please. Unique opportunity to see the basic skeleton on which everything is based. |
Formerly reformed
More answers to the question of why I cut the car in half.
![]() Note that, while the actual rear seat pans were cut out via plasma cutter, nature removed the longitudinal from the heater hole all the way to the pedal box area (and back around the other side of the car). All I had to do to pull the floor off was drill out the spots on the tunnel flange. The jaggedness along the frame (superimposed on the fan) is not from sloppy torch wielding!! The entire car was like that. Good news is that, though it has taken me 6 years to do so, I can now laugh in the face of the gentleman at Excellence who suggested- in print, mind you- the vehicle was to be considered as nothing but a mere, "parts car" that would take entirely too much time and money to restore. And all for under $5K!! Um, personal time, tools and shaping/forming classes not included.
AutoBahned
plasma cutter cost not included either
1966 - 912 - SOLD
GOOD ON YA, and keep it going-
i was too tired to be pretty last night! |
durn for'ner
I wanna know why you cut your hair in half?
Sorry man that was just way too easy..
Markus Resident Fluffer Carrera '85 |
Formerly reformed
Luckily, the plasma cutter (Thermal Dynamics Drag-Gun, with its own air!) was just borrowed for a year. Back in 2006! This project is really taking a looooong time!
I was beautiful with hair. Really. Striking, even.
Formerly reformed
OH MY GOD!! STEEL WOOL IS FLAMMABLE!! Somebody should warn people about this!!
Information Junky
Fenders will add to the rigidity of the whole, so the Q is whether you can weld them on w/o pulling significantly on the tub. Read: tack here, tack over there... lather rinse repeat. ( I would feel okay with removing the super structure once the main tub was done)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
