-   -   84 Carrera speedometer help (http://forums.pelicanparts.com/porsche-911-technical-forum/687150-84-carrera-speedometer-help.html)
Proudpapa4 07-04-2012 09:26 AM
Just got my speedo back from nhollywood and the odometer is working, but the speedo isn't. I was hoping someone could pull theirs and confirm my connections before I go crazy and start tracing wires everywhere for loose connections.
Leaving out the bulbs and starting with the red and black stripe
1. Red/black
2. Space
3. White/red
4. triple from outside moving towards center- br/red (same bundle as red and white), black, br/red no bundle
5. From outside moving towards center- double brown (2 wires), brown/red to bundle, all brown bundled with all black wire
I appreciate your help!
Proudpapa4 07-05-2012 11:07 AM
Bump hoping someone can help me out with this
Proudpapa4 07-06-2012 04:46 PM
Wow talk about crazy, my speedo works sometimes then dies, then works again depending on how long I drive it. Anyone experience that before with a freshly rebuilt speedo?
rgrimm 07-06-2012 06:50 PM
Don't know if this helps any, but when I pulled mine to send it to NHollywood (odometer), here is one of the photos I took before I disconnected everything. It did work fine when I hooked it back up...
http://forums.pelicanparts.com/uploa...1341629414.jpg
Proudpapa4 07-06-2012 07:06 PM
It helps a lot, thanks Roger.
Proudpapa4 07-20-2012 05:09 PM
Just a quick update- I sent my speedo back to north Hollywood and e fixed it again for free, probably shipping knocking something loose. I can drive again and I am so stoked!
Thanks again roger!
