-   -   What do you do when 93 Octane is not Available? (http://forums.pelicanparts.com/porsche-911-technical-forum/687203-what-do-you-do-when-93-octane-not-available.html)
wgerow 07-04-2012 05:31 PM
Kinda getting my learn on about ROW euro cars, primarily 84-89 3.2 cars. One thing I have seen several times is folks saying their car is set up to take 93 octane. In many states this is no longer available. So what do you do??
Is 91 a major no-no in these cars?
Do octane boosters work? Some say no.....some say they use them
Are there economical mods that can be done to limit damages from using 91?
Do the mods limit the HP/performance of the car?
Thx
Tippy 07-04-2012 05:39 PM
Octane boosters are snake oil.
Maybe get a computer chip from Steve Wong who makes a 91 octane friendly fueling map and enjoy instead of worry.
Reiver 07-04-2012 06:44 PM
91 is fine. The European rating is diff than the US. Check it out and you'll find that compatbility is easier than you think.
Drisump 07-04-2012 07:41 PM
My Euro seems to run fine on 91, but I run 94 locally, however on tours it isn't always available...so 91 it is.
Eagledriver 07-04-2012 10:29 PM
91 should be fine. We have race cars with Euro pistons that run 91 octane.
-Andy
porwolf 07-05-2012 12:00 PM
Maybe this helps: From my original '79 manual:
http://forums.pelicanparts.com/uploa...1341518371.jpg
FrenchToast 07-05-2012 05:49 PM
Thx
Which states!??!?!?!?!????!? :mad:
EDIT: Been corrected by Quicksilver and JavaDog below. Thanks guys!
Take care!
wgerow 07-06-2012 03:36 AM
California and Maine for sure.....there are others. Appears to be harder and harder to find in some states.
93 Octane Gas - Locations Across USA - Page 5 - Corvette Forum
wgerow 07-06-2012 03:38 AM
Mostly talking about euro cars, which didn't have a cat., but had a pre-muffler. Yes, maybe they were/are supposed to have a cat. installed as part of Federalization, but many have been converted back to their roots of a euro spec beast
javadog 07-06-2012 03:55 AM
Whether or not the car has a catalytic converter isn't the issue. The engine compression ratio is the main concern, along with the fact that in some areas of the country we experience much greater temperatures than they do in Germany. A 1979 SC doesn't have a high compression ratio and can burn about any gasoline blend. A ROW 3.2 is a different beast.
I don't know what the fuel octane requirements are for a normally aspirated 3.2, offhand. If it's higher than you can buy locally, either setting the fuel quality switch in the Motronic ECU to position 4 or having a custom chip burned for you would seem to be two options. I have experience running a ROW 930 which was intended to use 98 RON fuel and reducing the timing on that car was one way of dealing with the problem.
People are used to thinking that you can deduct 4 octane points from a RON value to arrive at an equivalent R+M/2 value, but that's not strictly the case.
JR
FrenchToast 07-06-2012 08:05 AM
Yep. Cats only come into play when you're deciding between leaded and unleaded fuel. A car with a cat you can't put leaded fuel in. However, not all cat-less cars can take leaded fuel either. Now cars with dogs, that's a different story..... :p :D
It was around 1979-1980 when catalytic converters started to become mandatory for U.S.-sold cars. One of the reasons the 930 was pulled for the beginning of the eighties.
Guess I should be glad here we can still get 93. Wish we could get fuel without any effing ethanol though.
Take care!
Quicksilver 07-06-2012 09:33 AM
I'm no fuel expert, so follow what others say. However, higher octane fuel typically improves performance in most EFI gasoline/petrol cars. From trucks, cars, etc. plus modern day ones. There are obviously exceptions, but on most it will advance the timing. It is very noticeable when towing with a truck, newer ones as well.
However, when doing any track days or anything, I wouldn't recommend anything lower than 93.
Take care!
Increasing the octane will only improve the performance on a car with a knock sensor. The 3.2s don't have knock sensors so any extra octane doesn't do anything to improve performance.
The only appreciable improvement may be that some brands have improved additive packages for their premium gas that may keep injectors clean to help with long term reliability.
... Or you could put in some Seafoam every once in a while.
javadog 07-06-2012 09:49 AM
Originally Posted by Quicksilver (Post 6842643)
Increasing the octane will only improve the performance on a car with a knock sensor...
... only if the current octane is insufficient and causing detonation, which then causes the computer to reduce the timing and thus also reduces the torque.
If there is no knock and the timing is not being reduced, increasing the octane will likely reduce power slightly.
JR
Eagledriver 07-07-2012 07:52 PM
While the Euro Carrera has pistons that are quoted as 10.3 compression ratio, they are actually less. For some reason Mahle quotes their piston CR based on zero deck height. Actual measure CR is usually .5 less. So the Euro Carrera actually has 9.8 CR.
-Andy
1derbar 07-08-2012 01:28 PM
I have a 1981 911SC and I use 89 octane. 93 is not available in Maine. With every tank of gas I add Marvel Mystery Oil, 104 octane boost, Lucas upper cylinder lubricant and Marine Sta-bil. My mechanic swears by the recipe, and the car's been running great! I do not have a catalytic converter, and I can get 100 low-lead at a local airport, but I'm not sure if that would be good for the car. Anyone know?
Quicksilver 07-08-2012 04:56 PM
AV gas has a different specific gravity then auto gas and a different vapor pressure. You should expect it to require different mixture settings to run correctly.
It probably won't directly cause any major havoc but I don't like to use "probably" as a guideline for the care and feeding of a motor that costs $10k to rebuild.
BTW - If you have a stock US market SC then 89 octane is fine. All the other stuff is just helping the cash flow. STA-BIL is a good idea if the car is driven infrequently. Other then that just buy a quality gas that has a good detergent package. Chevron and Shell are good choices.
Eagledriver 07-08-2012 04:58 PM
Do not run 100 LL in your car. The lead makes white deposits in your combustion chamber and can cause sticking rings.
-Andy
Tippy 07-08-2012 05:37 PM
<div class="pre-quote">
Quote de <strong>Quicksilver</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">Increasing the octane will only improve the performance on a car with a knock sensor...</div>
</div> ... only if the current octane is insufficient and causing detonation, which then causes the computer to reduce the timing and thus also reduces the torque.
Carrera 3.2 electronics wouldn't know if the engine is detonating - thus no retarding of timing.
Juggino 07-08-2012 05:52 PM
Just go to any auto supply and buy NOS octane booster, should add about 7-9 more octane even though it says 10.
GH85Carrera 07-08-2012 07:03 PM
Just don't worry about it. There is almost no 93 in Oklahoma. I can buy 100% gas no ethanol, but 91 is about you can find. It has never been an issue in 16 years of driving.
Tippy 07-08-2012 08:33 PM
Do you have data for this? Data I've seen would show about 1 point of octane higher, take 91 to 92 octane.
Arne2 07-08-2012 08:46 PM
Nothing higher than 91 here in Western Oregon, even the non-ethanol (which is tougher to find). My car had a 91 octane SW chip in it when I got it, which was installed by the PO in Washington. So I'm guessing no 93 in Washington state either.
pksystems 07-08-2012 09:54 PM
Toluene is the primary ingredient in those. Alot cheaper, and you need like 10% to have any effect on your gas. That's alot more then you get in one bottle.
I'm leaning towards adding ~5L of toluene before I fill up the tank in my turbo project, since most Canadian premium has such a low octane.
darcher 08-22-2012 07:59 PM
I run 91, occasionally 92 when I can find it but 91 is what's around town here and we've had no problems whatsoever. Don't waste your money on ocatane boosters. I do know some guys who are running some pretty exotic motors and go to the airport and buy 104!! but I'm running a stock 3.2 and do fine w/pump gas.
