-   -   how difficult is it to replace oil lines on a 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/68737-how-difficult-replace-oil-lines-3-2-a.html)
R22tech 05-16-2002 04:35 PM
I've got 2 leaks : they are both coming off fittings under the car behind the rr wheel. I tried tightening the fittings but they don't seem to budge. One of the lines is connected to the thermostat and is leaking where the hard line transitions to rubber. The leaks are very minor-they don't drip on the floor, but I'm thinking I might as well replace the whole lines if it's not too hard to do.
89911 05-16-2002 07:00 PM
I've replaced these on mine for SSI conversions. After draining the oil, I used some heat (propane) but they didn't budge. Ended up spliting the nut with a dremel cutoff wheel and then spreading the nut. The ones to be careful with is the thermostat threads that are aluminum. Use plenty of heat and the means above. Don't trust brute force.
KTL 05-16-2002 11:00 PM
Use heat, but let it cool. The nut and thermo. housing are different metals. The thermo. is aluminum and expands more when heated. Soft aluminum and tight fit can equal galled threads! Make sure to clean all the crud off the connection at the thermo. Not just near the threads, but on the back side of the nut at the oil line itself. It can bind here too. Use a good penetrant like Wurth, PB B'laster, Kroil, etc. Don't trust Liquid Wrench alone!
The line that changes from rubber to metal and winds around the rear (crank pulley side) of the engine can be rough. That connection gets a little crusty. A couple of snug crescent wrenches, your baby sledge, penetrant pre-treatment, and some good whacks will get you home. A helper is good to have for this crusty connection. Preferably not female. No offense, but they don't take kindly to having hammers swung near their hands and sometimes can't counterhold worth a crap.
Not too hard to do physically, but pretty hard on the wallet.
