Seconds Hand in Clock
1988 911 Coupe.
Clock in car keeps time just fine but the seconds hand doesn't work. Any quick fixes? |
The diabolicalist
I don't think I realized that it had a seconds indicator. I thought it was just a way to mark when you left for your trip? Haha
My junk: 1988 3.2 Targa- Damn near option-less! Crawl with me into tomorrow or I'll drag you to your grave. I'm deep inside your children... they'll betray you in my name!! |
RETIRED
It's a movable marker to keep time. It's explained in the owner's manual.
When in doubt RTFM.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
The diabolicalist
Ain't got the ****in manual.
The diabolicalist
Maybe we should read minds
RETIRED
RTFM was a ******* joke. Cool yer jets.
I would suggest the Bentley manual and Wayne's 101 projects. Excellent resources.
Senior Advisor
i did that also but if you look at the needle it is attached to the glass, then i read the OM
08 Cayenne Turbo |
The white marker needle is attached to the glass via the center knob. Rotate the knob with slight inward pressure to move the needle... push the knob or spindle in further to set the time. If your clock is slow or stops working, you probably have a bad, or possibly two bad capacitors. There are several threads on how to change them in the forums........
Tim ditto. As my Grandfather always told me-"when all else fails, read the instructions..." again, who ever thought of a trip or time marker? it does look like a 'seconds' hand.....
R&D guy
Location: the border between the states of inebriation & confusion
Here's a link to an '87 owners' manual posted on-line:
1987 Porsche 911 Owner's Manual The '87 & '88 are quite similar, and the clock is explained on p. 33. This manual proved invaluable in figuring out the HVAC controls. It may be possible to purchase reprints of the manual, or find a copy on eBay. I purchase a reprint for my '87 a few years back, and find it helpful and interesting. Last edited by dw1; 07-06-2012 at 04:41 AM.. |
come on by Chris's German Auto today...I will be there to show you how that clock works and answer any other questions you might have - great day for a drive anyhow....email me at (my user ID) xxxxxxxx@msn.com - I'll make you a cup of coffee too
Ed M 86' Coupe |
Diss Member
RTFM is just a fun multipurpose FLA. The M can mean Manual, or Monitor, or even Mind (I guess).
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
The owners manual "explains" the clock - but not in a way that makes any sense.
The way I see it, you set the white hand to "guess" how long a trip will take you and then you race to beat your original guess. Or, you put in the time that Google or other map program says it will take....then you try and beat it.
that second hand in your clock is manual. you just have to turn one notch every second using your preferred hand. either right or left hand works. no tool necessary.
I just keep it stationary so that it is so precisely accurate once every minute. well, at least i'm not lying.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
RETIRED
