Anyone installed a gauge in the empty, rectangular slot right of the driver's vent?
Hey Guys,
I'm planning to run a J&S Safeguard for knock control in my '87 Carrera after an engine rebuild, and I'd like to find an inconspicuous location for this knock/retard monitor: http://forums.pelicanparts.com/uploa...1341580029.jpg I noticed that there is an empty, rectangular gauge slot (I believe for a headlight height control level?) in between the driver's side vent and the headlight switch. The gauge from J&S is a standard 2 1/16" size, and obviously won't fit this slot. However, all I really care to see is the stack of LEDs on the gauge. John from J&S has agreed to provide me just the electronics within the gauge, so that I can install "the gauge" in rectangular slot pictured below. Has anyone had success mounting a gauge here? http://forums.pelicanparts.com/uploa...1341580795.jpg |
Bump. Just curious if anyone has installed gauges here. I would love to see some pictures!
on such a nice looking car i don't think id be cutting holes in the dash
I've seen the driver's ac vent replaced with another vent that had a boost gauge in it. Perhaps that's an option.
http://forums.pelicanparts.com/uploa...1155429709.jpg |
or a slot in your central pod.
Quick clarification - that's not my car ;) I just posted one that pictured the rectangular section I'm referring to. Yeah, I'm lazy.
I'm interested in that particular spot because I think it would be a very clean install. Basically, I'd just like to see the LEDs appear within that rectangle. |
For me that area would be partially hidden by my arm and possibly the steering wheel.
Here's an idea, albeit probably not cheap. Send the electronics along with your oil temp/pressure guage to North Hollywood Speedo. Have them inlay the new lights into the blank area at the top. Now you have all you 'engine monitoring' mostly in one spot. J |
How about just using premium gas, then you won't need the gauge.
DON'T CUTUP THAT BEAUTIFUL DASH! please
Think the NHS idea is the least invasive idea |
Yeah, North Hollywood for sure. Make it look stock and like it's supposed to be there, if at all possible.
how about replacing the clock?
put it in the carpeted kick panel.
http://www.vwgolf-mk2.com/modificati..._gauge/005.jpg
You could probably adapt something like this, no? Made by "duostyling" They make a range of gauges. |
Are you talking about the 2 AC vent in the center? The witdh/height ratio seem to be different than the gauge above. Since my A/C is out, I would like to fit some gauge there. |
Thanks for the idea. |
If you remove the ashtray, you can put a bracket there like I did to hold a voltmeter plus my (aged) XM radio...
http://forums.pelicanparts.com/uploa...1341834078.jpg Chuck.H '89 TurboLookTarga, 336k miles |
Remove the ashtray and hang it there...
| All times are GMT -8. The time now is 12:24 PM. |
