redstormcoach's Avatar
964 rear bumper update on a 1982 911SC
Hello,
I just finished a 964 update to my 911sc and I have question regarding the rear bumper.
I noticed that their is a gap under the tail lights between the new bumper. There is a seal between bumper and rear fender and a seal between bumpoer and rear reflector but I cannot find a part to fill in the gap between the tail lights and bumper. I called our host and they said there used to be a kit but its no longer available.
So does anybody have any advice? What have others used to fill that gap? Is there something that I could put there that would go under the tail light on one side then go between the reflector and bumper then end under the other tail light?
Any ideas that will look professional are appreciated.
Jay
Old 04-25-2012, 01:20 PM
80-911SC's Avatar
pinch welting or fender welt ... any vw supplier should carry it ... pretty close to what is between the fender and the bumper ...
Old 04-25-2012, 01:59 PM
$ Short's Avatar
Would like to see some pics when your done. This is possibly in my near future.
Kurt
Old 04-25-2012, 02:18 PM
Welt seems to narrow to fill the void. The gap is about 1/2".
Here is a pic of the update
Old 04-25-2012, 05:13 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I used some foam tape. You can get it at Home Depot where the hvac stuff is. It's about 1/2 thick, 1/2" wide and sticky on one side. when it's installed it looks just like a rubber moulding.
Old 04-25-2012, 07:20 PM
rattlsnak's Avatar
You should also run the 964 Smiley strip in the front. makes the squareness of the bumper look much better.
Old 04-25-2012, 08:35 PM
80-911SC's Avatar
kinda have a dumb question but here goes ... what 964 is that ?? that is not a 964 ...
this is ... isn't it .... the red one looks more like a Carrera bumper doesn't it ....
Old 04-25-2012, 09:46 PM
80-911SC's Avatar
on the pinch welt .. the original post question was at the tail light ... not at the front ..
At the front most use a 964 smile ... and at the rear the fender to bumper uses a factory seal that looks just like fender welt ..
Old 04-25-2012, 09:49 PM
I'm not looking for a fix for the fender to number but for the tail light to bumper.
Old 04-25-2012, 09:53 PM
jmod's Avatar
Hi,
If you are using 964 tail lights on a 964 rear bumper you can use the early 964 tail light seals. Up to 1990 the tail lights seal wraps around the whole tail light. On my 79sc I had to cut the piece that runs across the top of the tail light to make it fit, but it seals the gap nicely. PN is 96463142000 / 96463142100. Unfortunately they cost $44.00 each from our host - ouch!!
Jim M.
79 911SC
Old 04-26-2012, 02:42 AM
I already have the seals the gap is below where the seal is.
Old 04-26-2012, 10:19 AM
80-911SC's Avatar
sounds like the bumper fit may be the issue .. can you post a pic of the rear end ...
Old 04-26-2012, 12:50 PM
Undocumented User
McLaren-TAG's Avatar
The front of the car looks great, but we keep talking about the rear and there's no picture of that!
Old 04-26-2012, 01:07 PM
80-911SC's Avatar
That had me confused also ...
Old 04-26-2012, 04:03 PM
Problem solved. Good 'ol weatherstripping.
Old 04-26-2012, 09:02 PM
Az911's Avatar
Send a message via AIM to Az911
What wheels are those?
72T RS look
96 993
Old 04-26-2012, 09:31 PM
Ronal R9's, stripped and powdercoated black.
Old 04-27-2012, 11:02 AM
pictures about the rear bumper and the fix plz? got same situation but with the origi lights 911 85
Old 05-05-2012, 01:48 AM
Science is NOT optional
rbogh901's Avatar
Does anyone have any info for converting the rear lights/bumper to 964/965?
PCA member since 1993
Old 07-06-2012, 09:52 PM
