Hand brake, E brake, does this look right?
Hi,
I'm putting my trailing arms back together on my 1973 Targa. Somehow the assembly doesnt look right. I thought the nuts were supposed to be one on each side of the plastic clamp on the trailing arm, but this is how it looks on the car:
It is half an inch off on one side, and almost an inch off on the other. Is this really right?
I have new hand brake wires, but forgot to order the tubes so I used the ones from my 1970 T Coupé. Does the assembly differ between 1970 and 1973?
Any advice would be very appreciated.
Regards,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 07-02-2012, 01:30 PM
The bracket on your trailing arm should have a c shaped opening on it for the metal nose piece to fit into. the two nuts are for adjustment and stay towards the middle of the car.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-02-2012, 01:48 PM
Thanks,
Yes, they are C shaped, maybe not as C shaped as new ones, but anyway. So, the nuts shoud not be on each side of the C clamp? I thought they had to, to keep the wire from touching the cv shaft.
Regards,
Johan
Old 07-02-2012, 01:59 PM
no the nose piece fits into the c bracket and the nuts are both on one side. It's hard to see with my wheel on but I would assume the steel nose piece is trapped to provide the counter. one nut probably adjusts and the other is to keep the adjustment hold that nut in place.
1991 C2 Turbo
Old 07-02-2012, 02:11 PM
you can see your nose piece has a shoulder but since your bracket is worn away it won't hold it.
1991 C2 Turbo
Old 07-02-2012, 02:13 PM
Hi guys,
thanks, excellent advice! I managed to get it together now, and it works great. But, to get it good I need new c-clamps as you said.
Regards,
Johan
Old 07-08-2012, 01:48 AM
schumicat's Avatar
those nuts adjust the tension on the hand brake line so that each side pulls equally when you use the brake. one is a locknut and the other adjusts the length. there's a tech article on host site which explains the procedure.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-08-2012, 05:54 AM
