Original color? or primer?
I took off my door panels and it looks like a dark green, forest green? This is a 1969 911T and its red. Is this green primer or something like that sprayed on before the finishing coat was applied? I can't find green on anything else, just the inside of the doors.
I've seen a bright yellow primer used on cars (European style, I think) but am unfamiliar with green as a primer. Maybe someone else knows... Are both doors like that?
regards, jlex. |
Have you checked your paint code??
Both doors are like that, even inside part of it is sprayed green. I'll check the paint code once i find my vin number
| All times are GMT -8. The time now is 06:51 PM. |
