Arnage
I want to use a thru-the-hood filler for my R build on a '66 tub. The SWB tub does not accommodate the large fill neck so it appears I need to use a space saver tank from a latter model SC or Carrera thru 1989. Any help is appreciated.
yes it does
you will have to make some adapter fittings between the tank and the existing fuel system, but its a bolt in get a new foam gasket seal while you are at it
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Arnage
Thank you TRE Cup
