1976 911S no spark
I have a 1976 911S that has not run in a while but ran great last time it ran. I went to try and start it the other day as I'm putting it up for sale. It turns over like it should and I am getting plenty of fuel but no spark after lots of work with test lights and meters I have found power at the CDI but after that no power at the coil should I be able to find power at the coil? if so where when and how much? Also is there a way to tell if the CDI is functioning (CDI does make humming noise)? is there also a way to test the coil? Thanks in advance for the help.
PS if your looking for a Porsche 911 project this one is for sale I posted it in the classifieds section. ![]() ![]() ![]() ![]() ![]() |
Remove the distributor cap and clean/gap the points. Then, have somone try to start the car in the dark while you look for arcs across the old ignition wires.
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
I already cleaned the points but ill check them again and then look for arcs in the dark thanks for the tip.
Banned
Make sure they are opening.
