-   -   Trailing arms ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/6885-trailing-arms.html)
BK911 08-06-2001 10:14 AM
Trailing arms ??
Hello!
I would like to install aluminum trailing arms on my 70T. I was told 74 trailing arms would be a direct bolt on and I could reuse my brakes, hubs and shocks. But with 75 and above trailing arms, my brakes would work but not my shocks. How about my hubs? Could I bolt on my 70 hubs to the 75 trailing arms, or use the 75 hubs? Anybody done this? Please advise!!
Thanks!
BK
BRAINIAC 08-06-2001 08:58 PM
You need to change to the later hubs and grind off about a half inch off the snout where the shocks bolt to the trailing arms to make the shock angle correct.
Tyson Schmidt
72 911 Cabriolet
92 C-2 Cabriolet
