993 tranny only shifts into R, 1, 3 and 5
I was driving today and the tranny locked me out of 2nd, 4th and 5th gear. It shifts perfectly into the other gears. Any ideas?
Coupler ?
also, there is a linkage pivot fork in the tranny which, if loose, will cause that type of problem. (happened to my 915) #6 comes loose from #5 at one end, causing the pivot to work n only one direction. (again, this is for the 915 ...your 993 may be quite different) http://forums.pelicanparts.com/uploa...1342145096.jpg |
Could it be the pivot shift bushings?
That's what I was going to say. After I replaced my coupler (prior to proper adjustment) I "lost" those gears too. |
| All times are GMT -8. The time now is 04:31 AM. |
