-   -   Running headers ? you might want this (http://forums.pelicanparts.com/porsche-911-technical-forum/688629-running-headers-you-might-want.html)
Geneman 03-12-2013 05:55 AM
how to get these?
i would like a set!! what is the link on ebay to get them? or can i order direct thanks frank rauscher@wistar.org
advtracing 03-12-2013 11:24 AM
Originally Posted by proffighter (Post 7323517)
very permanent ;)
advtracing 08-13-2013 07:24 PM
some more listed on ebay
Geneman 08-13-2013 08:34 PM
Adv love mine beautifully made .. Just had to blow off the slight sheeps wool that came in the package .. Very nice product. Frank
advtracing 08-13-2013 08:38 PM
arrr the sheep joke ... how are you ? hows the project coming along
toddu 08-13-2013 09:14 PM
Crap, one more thing I need.
Todd
advtracing 11-01-2013 06:51 PM
Some listed on ebay Porsche 911 Heater Duct Cover Plates | eBay
911pcars 11-01-2013 11:18 PM
Originally Posted by car 311 (Post 7043899)
the bottom of a coors light can and a hose clamp worked fine....
For those of you on the fence post. The al. can strategy works fine on the engine side of the ducting as a block off when using non-heat exchanger headers. A simple hose clamp will affix the can bottom here. Advtracing's bolt-on versions are designed to mount to and block off the chassis end of the duct.
If using heat exchangers, it's suggested to maintain the engine-side ducting so cooling air can circulate through the heat exchangers.
Sherwood
advtracing 11-05-2013 12:40 PM
Sherwood
many ways to skin a cat ..as they say
a beer can bottom will sure work to cover the heater pipe but i set out to do an item that sealed the chassis and pipe from dirt and moisture . chassis is the most prone rust area
advtracing 11-25-2013 03:54 PM
Big old bump
advtracing 12-11-2013 04:39 PM
whipped some more up
