georgew123's Avatar
3.2 Magnecor - Wrong Coil Wire Connector?
I don't know if I am missing something, but I am replacing my original wires with Magnecor 8.5's and upon disconnecting the coil wire from the coil, the connectors are not the same. It appears one is a "male" connector and one is a "female" connector? Any thoughts would be greatly appreciated!
First picture was just in case you needed some reason to help.
1985 911 3.2 Targa
1985 911 Targa (Black/Black)
Old 07-13-2012, 07:54 PM
rsscotty's Avatar
The Magnecor wire should fit into your 3.2 coil just fine. You should be good to go.
Old 07-13-2012, 08:55 PM
georgew123's Avatar
In the 2nd picture the old wire is to ths left and the new wire is to the right. As i think can be seen, the old wire has a solid metal center peice that would appear to enter into a hole on the coil to connect. The new Magnecor wire has a more standard receptor that would fit over a receptor with a solid center.
I did some searching online, but I am just trying to verify that the new wire will fit the coil (which may not be original) due to the vastly different appearance of the connector.
Old 07-14-2012, 03:46 AM
Call them
You can call magnacore direct and order the right wire and to the length you want. Very reasonable, and the ship out real fast. I have always had good service and support from them. I just order a two foot long center wire so I could reposition my coil and they came thru with flying colors.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 07-14-2012, 06:16 AM
georgew123's Avatar
I emailed Magnecor, as I really don't see how these connectors are compatible. Hopefully I am wrong and can be back on the road by Monday.
Old 07-14-2012, 07:04 AM
RSM-M491's Avatar
I am curious to see what you find out. I had the same exact problem a couple of months ago, and just left the one that went to the coil in there. But replaced the rest.
Let me know!
Rod
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 07-14-2012, 01:34 PM
gtc gtc is offline
abides.
gtc's Avatar
I just checked, and my Magnecor 8.5 coil wire connector looks the same. It fits and works just fine.
Graham
1984 Carrera Targa
Old 07-14-2012, 01:55 PM
LJ851's Avatar
1985 911 3.2 Targa
It looks to me that "female" connector is actually a hollow male connector, the OD looks very similar. Have you tried to install it? I bet it fits just right.
Old 07-14-2012, 03:01 PM
Go online and download the Magnacore product manual.
Look up the style you need, and call them on the phone and talk with them about it.
For some reason I didnt have any luck with email.
They are friendly and are willing to help you with your questions.
But the one on the right looks like the Female plug I use on my MSD....I think it is wrong.
I have no doubt it will fit but I dont think it is correct.
Old 07-14-2012, 04:56 PM
fastfredracing's Avatar
This
No left turn un stoned
Old 07-14-2012, 04:58 PM
m110's Avatar
Let me know!
Rod
I did the same thing and have the unused new coil wire hanging around for 5 years. I don't see how it would work.
1988 Carrera Coupe
Old 07-15-2012, 02:44 PM
gtc gtc is offline
abides.
gtc's Avatar
Coil wire skeptics... sheesh.
This place cracks me up sometimes.
Graham
1984 Carrera Targa
Old 07-15-2012, 03:35 PM
DanielDudley's Avatar
They are both male connectors, and dependent on contact on the outside. Doesn't matter if it is hollow, it only maters if there is some spring pressure pushing to the outside.
Empirically, the way to find out if it works would be to try it...
Old 07-16-2012, 01:28 AM
BTW, In the old days I changed hundreds of these wires on a daily basis. The vast majority of coil wires look like the Magnecor.
Old 07-16-2012, 01:30 AM
georgew123's Avatar
I installed the new coil wire and hopefully will have it all together tonight to verify that despite their vastly different appearance, it works just the same. I also exchanged emails with Magnecor over the weekend and they agree that it works. Thanks to everybody for their responses and reassurance. I guess the rest of the guys holding onto oem coil wires should swap them out?
Old 07-16-2012, 04:50 AM
georgew123's Avatar
Okay... got it done. Used the new Magnecor coil wire and temporarily left off the coil "cover" to verify that there was no obvious signs of it not being fully connected. The car ran slightly better, but seemed a little down on power (as it was prior to the new wires).
Anybody have an opinion as to whether a distributor having too much vertical play could cause slight loss in power? About a month ago I installed a new cap and rotor (off-brand, but quality replacements are in the mail) and the new cap seems to have only wear on the absolute bottom of the elements for each cylinder inside the cap. Just doesn't have the punch it used to in lower RPM's.
Old 07-16-2012, 07:03 PM
