jmartin
911 Smog pump injector hole thread size?
Does anyone know the actual thread size for the hole in the cylinder head for the smog pump lines? I broke one off removing and need to repair. If I can't go back to original any suggestions? Thanks
Old 07-16-2012, 08:23 AM
10x1.0. pelican sells a 914 rear caliper plug with a shoulder that fits great. i use 1/8 hex head brass pipe plugs. basically the same thread count, but on a taper so it binds 2/3 of the way in and stays put. and easy to find.
206 637 4071
Old 07-16-2012, 08:43 AM
jmartin
I thought about tapping for a 1/8" plug but wanted to here what someone else has done. Thank you!
Old 07-16-2012, 01:21 PM
no need to tap for the 1/8" pipe plug. just run it in until it's tight. allen head or square head are harder to get tight. find some hex head plugs.
206 637 4071
Old 07-16-2012, 02:27 PM
jmartin
Ok, Thanks!
Old 07-17-2012, 05:18 AM
