Removing front calipers without disconnecting?
I'm replacing the rotors on my Carrera 3.2, and I can't seem to figure out how to remove the caliper without disconnecting the brake lines. I know I can just bleed them out again, if I have to, but I'd rather keep it cleaner and keep the system closed while I replace the rotor.
Am I missing something? At least on the rears, I was able to get a little bit of flexibility from the hard lines by removing the clip where they met the rubber lines.
-Neil
PS: Am I the only one who's noticed that Carrera is tagged by the spell checker here? ;-)
Old 07-17-2012, 09:48 AM
Senior Member
Jdub's Avatar
Before you remove the caliper, be sure to lever the puck into the caliper body by opening the bleed nipple as you lever the pad in using the appropriate screwdriver or equiv. No worries on scarring what you will be throwing away.
This room will allow you to slide the new pads in later without a huge mess.
Needless to say this is the time for new hoses if you have not already replaced them. If you do so, do not attempt any loosening without true brake wrenches and PB Blaster or equiv. to loosen things up. Also, wheel bearings are typically analyzed and replaced at this time since you will have the "hat" off.
'78 Targa in Minerva Blue
Old 07-17-2012, 10:27 AM
Once the pistons are pushed back into the caliper you can lift them off without disconnecting the brake lines. Don't be afraid to muscle it out of the way. If you are somewhat worried, loosen the bearing nut to remove the rotor and pull the rotor and lift the caliper if you feel better doing it that way. I never bleed pressure via the nipple, but that is just my choice. Once the new rotors and pads are on and the caliper bolted back in, then do your flush or bleed.
Make sure you bed in the new pads.
Tony G
2000 Boxster S
Old 07-17-2012, 10:40 AM
RETIRED
Joe Bob's Avatar
Pull the pads....
2012 ML350 3.0 Turbo Diesel
Old 07-17-2012, 10:44 AM
I always disconnect the lines. If you don't you have to bend the hard lines too much IMO. Easy way to minimize the fluid loss is to hold the pedal depressed an inch or so with a stick. This keeps the fluid from flowing from the reservoir to the open line. Very little fluid will escape.
-Andy
Old 07-17-2012, 03:07 PM
porsher
aston@ultrasw.c's Avatar
-Andy
x2 That's how I do it.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-17-2012, 03:22 PM
they're metal lines, so you need to disconnect or you'll damage them.
206 637 4071
Old 07-17-2012, 03:25 PM
Hydrocket's Avatar
Pull the pads....
Yea...pull the pin, remove the pads then (if need be) push the pistons back in to make room for the thicker new rotor.
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 07-17-2012, 03:39 PM
