polizei's Avatar
Hard Oil Line thready damaged by aggressive dremel user - Am I out of luck?
Guys,
I've been trying to disconnect the hard oil lines from where they connect to the short flexible lines - just before the front oil cooler on my '87 Carrera. I tried employing the approach of taking some material off the large 36mm nut with a dremel, but I ended up going just a little too far.
Remarkably enough, the new short oil lines thread onto these damaged threads just fine. Can you take a look at the below pic and let me know whether you think this requires repair, replacement or have I lucked out?
Andy - 1987 911 Carrera Coupe
Old 07-21-2012, 05:32 AM
Northern Motorhead
wildcat077's Avatar
The only way you'll know is if you install everything back together ...
If it threads fine then i would take a chance and see !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-21-2012, 06:12 AM
RETIRED
Joe Bob's Avatar
Fire it up and try it......your other alternative is to braise another fitting on.
2012 ML350 3.0 Turbo Diesel
Old 07-21-2012, 06:37 AM
Hi
Targa Me's Avatar
I did more damage than that when I replaced an oil line and it sealed up nice. Give it a try.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 07-21-2012, 06:45 AM
redridge's Avatar
If it doesn't work out I have a set of hard lines used in pretty good shape.
Old 07-21-2012, 06:49 AM
the actual sealing is between the ball and socket. the threads only pull the parts together. should be fine.
206 637 4071
Old 07-21-2012, 08:09 AM
Paper Member
Maybe wire brush that area really good. As long as it doesn't damage and strip the threads on the mating piece you should be OK.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 07-21-2012, 08:16 AM
Weekend Mechanic
vulcan300's Avatar
Use plenty of never seize and put it back together. As John Walker says, the threads don't provide the seal. If it does end up leaking some oil perhaps some high temp silicone tape might do the trick.
86 911 Carrera Targa
Old 07-21-2012, 12:26 PM
What did I tell this morning.......
Andy,
It's good to ask second opinion about things and I do that a lot too. Now you know I'm not just a pretty face (???). You'll be alright.
Tony
Old 07-21-2012, 01:39 PM
