-   -   turn signals don't work (http://forums.pelicanparts.com/porsche-911-technical-forum/68989-turn-signals-dont-work.html)
davis911s 05-19-2002 09:10 PM
OK I am sure this is one of my dumbest questions. I am sure my problem is the relay, But where is the relay at?
My hazards work, my high beam/ low beam works. Just NO SIGNAL LIGHTS at all!!
So I am sure it is the relay but where the heck is it? I should know this I know, I have owned the car for 4+ years and do all the work myself, but I DO NOT even know where this relay is. Please don't be too harsh on me.
Also there should be two seperate relays, one for the signals and one for the hazards right??? Can I swap them to check? I am assuming yes.
Shawn
epbrown 05-19-2002 11:03 PM
On my '83, they're located behind the fuel/oil level guages.
Emanuel
davis911s 05-21-2002 11:59 AM
That is where it is on my 77 too. Now here is the funny part.
There was only one relay there, (same one for the hazards and turn) so I doubled checked the fuses AGAIN, they looked fine but I decided to replace the fuse. That was the problem!
Point to note- even if the fuses LOOK good, sometimes they are pooched! Another lesson learned.
Shawn
