-   -   cheap attempt to address sagging c-pillar liner (http://forums.pelicanparts.com/porsche-911-technical-forum/690265-cheap-attempt-address-sagging-c-pillar-liner.html)
midnight911 07-22-2012 10:19 AM
c-pillar liner is starting to leave its place.
attempting few cheap resolutions to keep it in place...sort of.
http://forums.pelicanparts.com/uploa...1342977360.jpg
which one's do pelicans think the least ghetto and "okay" resolution?
the material i'm using is black 1/32 ABS panel.
1. small strips
http://forums.pelicanparts.com/uploa...1342977430.jpg
2. a panel covering up the whole area
http://forums.pelicanparts.com/uploa...1342977473.jpg
3. something down the middle...
http://forums.pelicanparts.com/uploa...1342977532.jpg
other ideas welcome.
motorcop 07-22-2012 11:14 AM
#2 looks best with a large piece covering the whole area. Could even mirror it and put on the driver side so it matches....just my 2cents.
wayner 07-22-2012 02:29 PM
Why is it pulling loose?
My guess is rust in the window Chanel due to leaking seal
56 nomad 07-22-2012 04:14 PM
why not try to get some stock material and if you are going to glue it on us that not the felt. jm2c, ben
porsche930dude 07-22-2012 06:56 PM
like #2 but do it up to the seam in the headliner and big enough to tuck in the rubber. If you do a good enough job it should almost look like its suposed to be like that
redstrosekNic 07-22-2012 07:03 PM
+1 on option #2. It will look fine if you take your time.
