bcheney's Avatar
89 911 engine fan
Can anyone confirm that the engine fans for all 84-89 Carrera's are the same? If so, what is the part number?
Old 05-04-2005, 06:20 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: 89 911 engine fan
The Carrera fans themselves are all the same, part number is 930.106.012.00. The housing that surrounds the fan impeller carries different part numbers depending on the engine code and year.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 05-04-2005, 06:29 PM
bcheney's Avatar
That was quick. All who particpate in this board are great. Many thanks. Brian
Old 05-04-2005, 06:31 PM
bcheney's Avatar
fan and housings
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 07-23-2012, 06:45 PM
bcheney's Avatar
broken blade...
Well...now I have a broken fan blade. It happened during the process of changing out the alternator...dont ask how...it just happened...I would assume this is terminal. Let me know your thoughts.
08 Cayenne V6
75 914-6 Conversion
Old 07-23-2012, 06:57 PM
I assume you have the broken piece? If so, I'd take it to a TIG welding shop that does aerospace/aircraft repair- Given all the different types of welding rods availabe today, they can probably weld it for a reasonable cost. It would then have to be ground down and sanded smooth to match, and then I would recommend having it balanced.
I had something similar done at a shop in Phoenix years ago- they produced welded jet engine parts for Garrett AirResearch. The guy who fixed a oil cooler for me had the most perfect, and tiny, TIG welds you have ever seen.....
If you can't find a shop to do it, send me a PM and I will ask a buddy in PHX about it. He builds $50k +++ 911 race engines- if it can be fixed, he will know who can do it. If you do end up sending it to PHX, Jim Patrick/ Patrick MotorSports, can check the balance, although any good machine shop that the local raceguys use could do the same.....
Tim
Old 07-24-2012, 02:28 AM
