H.G.P.'s Avatar
NO right rear turn signal but the same bulb works when the car lights are on???
Right turn signal does not work.....all the others do. Further, the same tun signal bulb lights when the regular lights are on.
I tried to swap the bulb from the left turn signal which works and the same thing occurs.....right light works but not the turn signal from the same bulb(s) ...including the substitiute bulb. Ideas?
69 911 "Little Bull"
Old 05-20-2002, 03:18 PM
Mark Wilson
Guest
Posts: n/a
Check your fuses. My 79 has individual fuses for each corner on the parking lights. Critter helped me with this one yesterday.
Mark
Old 05-20-2002, 03:22 PM
H.G.P.'s Avatar
Thanks I'll try that.. I think I have two banks of fuses. One bank above the other. I think they are labeled....I'll have to check. However,. I don't know the proper amps for these fuses?
Old 05-20-2002, 03:29 PM
