-   -   Stuck In Reverse (http://forums.pelicanparts.com/porsche-911-technical-forum/69078-stuck-reverse.html)
MFB 05-20-2002 02:54 PM
Stuck In Reverse
Hey all,
On my way to a routine service, I managed to get my '74 911 stuck in reverse. No matter which position I had the selector in, the car stayed in reverse (even in neutral). Thankfully, I was a block from the shop and was able to get a couple of the guys to come over and look. They were able to get it to the shop (in reverse). The initial thoughts were that it would require a re-build ($$$!).
Has anyone ever had this problem?
Any advice is appreciated as I am relatively new to the 911 world and would like to be able to talk intelligently to the mechanic when he calls to give me the diagnosis.
Thanks!
nhromyak 05-20-2002 03:11 PM
Most likely, the shift coupler just behind the front seats, in betwen the two rear seats is loose. Mine did this, and I freak, everytime. I adjusted, tightened and away I go!
Hopefully your shop will not charge you, presuming this is what it is.
Good luck.
Jim Sims 05-20-2002 03:49 PM
I agree, check the shift coupler. Jim
john walker's workshop 05-20-2002 05:07 PM
remove the backup light switch and push in on the pin that activates the switch until the reverse shaft is back in the neutral position. about a 15 minute job. usually this eventually happens because someone was inside the trans once and got a detent in the wrong position.
