-   -   Looking for rubber boot for oval hole near shift linkage pass through (http://forums.pelicanparts.com/porsche-911-technical-forum/690830-looking-rubber-boot-oval-hole-near-shift-linkage-pass-through.html)
Fricksman 07-24-2012 08:05 PM
I have searched through the parts catalog and cannot find the rubber boot that covers the oval hole near the shift linkage pass through in the tunnel. The only thing that goes through that hole on my 79 SC are the speedo wires. Anybody have any idea??
Porboynz 07-24-2012 11:28 PM
You could probably use the same boot that seals the accelerator linkage where it passes through the bulkhead on the other side of the gear linkage.
Bob Kontak 07-25-2012 07:02 AM
The seal is part of the assembly for the speedo wire.
Look up this part 911-606-209-00-M100
Pelican Parts - Product Information: 911-606-209-00-M100
Since the unit is $150 you now can free yourself from guilt by considering the $11 piece Poyboynz suggests.
911-423-593-01-M104
Look at your accelerator linkage boot and see if it may work. The accelerator boot appears longer and I don't think there is a lot of room front to back as there is where the gas pedal linkage comes out. This is just from memory. Not climbing under there this morning. :-)
Here is the accelerator rod seal. Is this what you are thinking porboynz?
http://forums.pelicanparts.com/uploa...1343224943.jpg
Porboynz 07-26-2012 02:13 AM
Thats what I would use, if its too tight you could cut it down a little and then use a zippy tie to make it water tight against the wiring.
Fricksman 08-04-2012 10:35 AM
Great idea. I'm sure I can make that work especially for the cost savings. Thanks Guys.
