giovanni86's Avatar
Michelin TB duration
Hi all,
I have the opportunity to buy a new set of michelin TB for my car... The question is:
what is the life expectancy of a set of michelin TB?
thanks in advance
Giovanni
Old 07-25-2012, 10:09 AM
martin_gibson's Avatar
With mainly fast road use (and the odd trackday) my set have just covered 12,000 miles and may have a few thousand miles left before they need replacing.
This particular set is from the first batch but I understand that the later tyres have a much softer compound, so the mileage will invariably decrease next time round.
Fantastic tyres by the way.
Martin
Old 07-25-2012, 04:04 PM
giovanni86's Avatar
Hi Martin,
probably my tyres are softer... I have done around 1K miles and I don't think to be able to cover 11k miles more
Anyway, fantastic tyres!
Have you tried other tyres? I think we are using the same rims
Bye
G.
Old 07-25-2012, 10:19 PM
Originally Posted by giovanni86 View Post
.....probably my tyres are softer... I have done around 1K miles and I don't think to be able to cover 11k miles more .
Wow 1k - are you sure you haven't fitted them to a Ducati
No I haven't tried anything else on this particular car but may try the new Pirelli P7Corsa Classics next time.
Martin
Old 07-25-2012, 10:57 PM
Mileage? If you can afford these tires, apparently money is not an issue.
When worn out, just buy another set which may be less money should you
choose a different brand
Old 07-30-2012, 04:54 PM
Tire life is very dependant on alignment -- lots of camber or toe will quickly wear any tire, so this needs to be considered. The tread wear rating on the sidewall is a better indicator.
What is the treadwear of the Michelin TB's? My Kumho's are 180 and with my current alignment (very little camber) I think I'll get 20k out of them at least.
Chuck.H
'89 TurboLookTarga, 336k miles
Old 07-31-2012, 04:26 AM
gumba's Avatar
A friend got around 10K on his '73 w/3.6 street driving only. His car is in the 2300-2400 lb. range. I got around 7K on my '79 turbo, street driving. My car weighs 2800 lbs. I had premature wear on the fronts due to the wrong camber setting.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 07-31-2012, 06:21 AM
giovanni86's Avatar
thanks a lot!
Old 08-01-2012, 03:46 PM
