Smuggler's box air tight?
My car had the A/C removed by the PO. If I crack a window at speed I get a breeze from lower "bow tie" vents. I assume this is the path of least resistance for air to fill the vacuum created by the open window.
The vents connect to a tube in the smugglers box which used to connect to the A/C blower -- now it's open to the box. Is this 'breeze' typical and the fix is to seal the vent hose or should the smuggler's box be air tight and this suggests a bad seal somewhere?
1980 911SC |
There are two tubes into the smuggler's box. The first is the one going to the bow tie. The other goes to the tunnel which is where I suspect the breeze is coming from. The tube to the tunnel was an input to the evaporator box.
Scott '86 911 Carrera Coupe, PCA, PBC |
I used a rubber cap for ABS plumbing pipe to seal this tube. Friction fit seems fine, so I have a spare large hose clamp as well.
You also have a small round opening for the drain old evaporator drain in the bottom of the box and a roughly trapezoidal opeing into the passenger footwell area that could be contributing sources of airflow. The linkage from the steering wheel to the steering rack also passes through the area and is open to the air above the belly pan. So to answer the original question, the smuggler's box is definitely NOT air tight.
Jeff '82SC Pacific Blue '02 C4S Silver (Gone but fondly remembered) '11 GTS Amethyst |
Good info guys, thanks!
1980 911SC |
Bill |
mine has a big gap around the steering column aswell right out to the road. Is there suopsed to be a seal of some sort there? i just stuffed a rag in there so mice dont eat my tools
82 SC , 72 914 |
Fleabit peanut monkey
Formerly known as Syzygy
Yeah, there's no way it's air tIght. With the AC removed, I would be tempted to hook up a fan there in that system as well, just to het some more fresh air into your face (dash vents) to help with cooling of the humans.
Flat Six
Correct
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Retired, finally
The fresh air really helps, and having the fan is essential in the SE.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Flat Six
Retired, finally
I can take some, although my install is pretty ugly.
I should have painted the PVC pipe black before I put the fan box back in the smugglers box. That fan box is one tight fit. I can see those damn Porsche engineers designing it with exactly 1mm clearance one each side.
Retired, finally
As promised, I am trying to post pictures of my A/C delete and fresh air intake. PVC is a 2" 45 degree union bought at Home Depot; red sleeve is 80mm silicone made for some turbo bought on ebay, but they have them at FLAPS, old flexible duct form blowr to dash vents was dry rotted; flexible duct is 3" x 4' Gates bought on ebay; NACA duct was standard single bought on ebay (had to trim end to fit when I moved my battery.
Also installed inline fuse to fan motor, as I was told this was unfused from factory. Just barely visible is aluminum plate riveted to front bulkhead covering intake hole from deleted front condenser fan. Haven't finished my battery cableing yet, still waiting on a kill switch kit to be delivered. ![]() ![]()
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project Last edited by SiberianDVM; 07-26-2012 at 04:55 AM.. |
