Hell bent to improve
Another new guy with build....
Hi all, for more than a year I have been trying to build a -73 rs recreation. Goal was to make a car that is nut and bolt built with a good engine and chassi upgrades. However it is also very important for me that the looks stays as original as possible. the build has progressed well but I have missed comments on it. This forum has helped me extremely much as this is the first time i do anything to a car.
This is what we started with.... Long way to go...
Luckily the car was solid and rust free. Sunroof stays as this is no pure racetrack car.
Old 07-26-2012, 02:15 AM
tazzieman's Avatar
Welcome and...good on you!
Can you tell us some more about your chassis history , and what other plans you have?
I'm sure it will be set up for Swedish drifting!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 07-26-2012, 04:35 AM
Dublinoh's Avatar
Welcome and keep the pictures coming.
Old 07-26-2012, 08:07 AM
Hi again and thank's for the response. As said we are pretty far along the path of the car so i´ll post some pictures and wait for the comment, good or bad :-)
Car was made rotating so the body could come of, we needed bare metal.
More like it, then to the coulour. We just loved the 114 Signal yellow
So signal yellow with black interior.
Car just back from paint so now we can start the fun stuff!
Boot with new gas tank and refurbed spare. All part are either new or restored to "as new".
Old 07-27-2012, 01:31 AM
Here are a few pictures of where the project stands today. Next weekend the engine and tranny goes in. Engine is a 3.0 sc with s-cams. 42mm italian Webers. SSI, rsr exhaust (love the double pipes). MSD ignition and 10.5.1 compression. We are aiming for 250 to 270 solid hp. Gearbox is a renovated 915.
Old 07-27-2012, 01:54 AM
Oh sorry Tazzieman! Forgot the chassis.
We are doin bilstein Rennen (clubsport) suspension, coloured black in the front for looks. Carrera 3.2 brakes. 27mm torsion bars in the rear and 19mm in the front. Weltmeister adjustable Sway bars front and rear. And then 16 inch Fuchs in 7 and 8".
Old 07-27-2012, 02:04 AM
Old 07-27-2012, 02:10 AM
wayner's Avatar
Very nice!
SOLD - 914 wide body hot rod
Old 07-27-2012, 03:01 AM
Thank you! I have seen your work and you have done a great one!
Old 07-27-2012, 06:42 AM
OttoB's Avatar
Wow! The devil is always in the details and you have done an outstanding job so far - good luck and welcome!!!
Old 07-27-2012, 08:19 AM
Thank you Otto! We really try to get into every detail to make sure that everything is perfect. Today it´s fuel system, seats and doorhandles. As the lock cylinders after rekeying works so and so I am thinking of putting a central locking on it. Would that be a bad thing?
Old 07-28-2012, 01:55 AM
Long nice weekend!
Hi all, well this weekend we got a lot done. Interior is almost done, only missing a fec electrics and the door cards. The central locking is in but acting up a bit, it locks and then straight away unlocks again. Probably somethhing not running completely smooth so that will be fixed today. BIG part is that the engine and tranny went in! So now the ride height is all done and I love the looks! Feels really good to be this close to the end. Engine compartment and luggage comp needs some clean up in terms of wiring but that should be done shortly.
Old 08-06-2012, 01:16 AM
Wood Magician
Beautiful work and excellent progress!!
Love the color as well, nice choice.
I have one critique however and that is the plated hubs that look like the wheel studs were not removed before plating. The yellow cad plating process causes uneven stress in the surfaces of fasteners due to the heat and chemicals as well as the metal that is deposited on the surface. In other words it can weaken and make the wheel studs prone to stress fractures which will lead to failure especially if they were sand blasted. It would be best to knock out the old wheel studs and put new studs in which is never a bad idea anyways.
I'm sure an engineer can chime in but I have been told this by two different platers I have used on separate occasions which led to some exploring of this knowledge-
Old 08-06-2012, 02:28 AM
Bird. It's the word...
Fishcop's Avatar
That's lovely!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-06-2012, 02:59 AM
Hi there!
All was removed from the hubs prior to glassblasting! The bolts was plated after that.
Old 08-06-2012, 03:03 AM
tassie targa 76's Avatar
WOW great work very inspirational
Regards Michael
project 1976 911 targa
everyday drive 1995 318i BMW
wifes car 2001 c200 kompressor coupe
spare 2006 mazda bravo ute
Old 08-06-2012, 03:17 AM
tazzieman's Avatar
Hey , you are the Scandinavian Magnus! And Magnus means "great" ; you are doing a great job ! Fabulous colour.
Old 08-06-2012, 05:21 AM
wayner's Avatar
I love the seats
Fantastic detail on the entire car!
Old 08-06-2012, 05:42 AM
Dublinoh's Avatar
The older cars are so awesome when restored correctly...I love it, great job.
Old 08-06-2012, 05:55 AM
MBAtarga's Avatar
Fantastic color!
Trombone cooler? Is that used for originality?
Mark
'83 SC Targa - since 5/5/2001
Old 08-06-2012, 07:07 AM
