Retired, finally
SiberianDVM's Avatar
need corner balance & alignment near Augusta, GA
My 911 needs a corner balance and alignment and I'm having trouble finding someone who can do it.
So far in Augusta I have had zero luck finding anyone with corner balancing scales and I really don't want to buy something I will rarely use. I did find an alignment shop that thinks they can align it.
My only good lead so far is Autometrics, in Charleston, SC, about 3 hours away. They said corner balance and 4 wheel align for $90/hour, probably a 3-4 hour job.
Anybody know anyone good a little closer to me?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 07-26-2012, 07:14 AM
I also live in Augusta, I had Drew Slayton in Aiken align my 911 a couple of months ago. Do an Internet search on him and you will find he has been building and working on Porsche race cars for years. He works part time at a Porsche shop in charlotte so, it may take a week or two to schedule an appointment. He aligns the old school way by strings. His number is 803 648-1428
Old 07-26-2012, 09:16 AM
DOC's Garage in Columbia may be able to help you.
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 07-26-2012, 12:11 PM
onboost's Avatar
I know its a bit far but well worth the trip to see Galermo @ the Aligment Store, right behind Andretti's on Hwy 9 in Roswell. Directly across from Jackson Acura.
RGruppe #180
Old 07-26-2012, 12:22 PM
Retired, finally
I thought they would as well. When I called them today they didn't seem able or interested. They did give me the lead on Autometrics, however.
Old 07-26-2012, 01:26 PM
Retired, finally
Strings? Geez, the car is old, but....strings? I appreciate the info.
Old 07-26-2012, 01:27 PM
Retired, finally
Thanks. Charleston is probably a bit closer, and a nicer drive.
Old 07-26-2012, 01:28 PM
toddu's Avatar
Never been in the garage area at the races???
Old 07-26-2012, 03:45 PM
I was paying Drew a compliment saying he aligned with strings. If if it is good enough for Porsche race cars it is good enough for my 911
Old 07-26-2012, 05:04 PM
Retired, finally
Nope, never been in the garage areas. Learn something new every day.
Old 07-27-2012, 04:16 AM
i have done that in my garage at home after installing turbo tie rods on the 88 and it works pretty good.
Charles
88 911 Cab
74 TR6
88 CRX Si
Old 07-27-2012, 06:32 AM
toddu's Avatar
Didn't mean to sound like a douche by the way....
'81 SC
Old 07-27-2012, 06:51 AM
dshepp806's Avatar
Pack it up and head to Atlanta! Lotsa' guys there who don't use strings.....
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-27-2012, 08:23 AM
Franz Blam in Tucker, GA its not a bad drive from Augusta and its closer than Charleston...
Old 07-27-2012, 11:41 AM
dshepp806's Avatar
That would be my first suggestion,..he's one of the BEST!!!!!
Good luck.
Doyle
Middle Georgia
Old 07-27-2012, 12:33 PM
Retired, finally
No prob. I did do a google after y'all mentioned the strings, and I found a good article explaining it. But at the very end, it mentioned that the guy no longer uses strings: he uses a tripod mounted laser so he doesn't have to worry about tripping over the strings.
Old 07-27-2012, 01:14 PM
I home aligned mine with strings then took it to a pro to verify....gave him the paper with my settings...he kinda smirked....came back to get me within a few minutes and showed me the readout while the car was still on the machine....I was dead on where I thought I was.
I may never go back to an alignment guy again for the Carrera.
1986 3.2 Carrera
Old 07-27-2012, 04:53 PM
it gets you very cloes in the ball park to comforatably drive the car to a a prof.
Charles
88 911 Cab
74 TR6
88 CRX Si
Old 07-27-2012, 05:37 PM
Elombard's Avatar
Yah, I was amazed when I did one with strings on my 73 hot rod (camber with a magnetic level), took a couple of tries and a lot of time but it did not pull and I never had any tire wear. I used the tripod method for a rough corner balance and I am starting to think that is more important than the alignment. Once the CB came together the car was magical to drive. I was always fooling around with the ride height and trying different parts on the suspension so repeated alignments and CBs would of been really expensive.
Now the bad news - on my 97 M3 when I installed an adjustable suspension and some spherical bushings I guess I was a little cocky - ate the inside of the front tires to the cord in fairly short order and had it reset by a local run of the mill shop when I replaced the tires. Alignment on an 90s m3 is very similar to most cars on the road unlike the torsion bar 911s.
I am in Conyers and not too far from Augusta and would love to do it with you but I just dont have time any more.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-27-2012, 05:51 PM
