-   -   Upgrading Engine (http://forums.pelicanparts.com/porsche-911-technical-forum/691515-upgrading-engine.html)
maui44 07-28-2012 09:19 PM
Upgrading Engine
Down the road, I am thinking of Upgrading my engine (2.7) to a 3.2.
There are a few questions I have.
1. Is it a lot more work (labor) to go to 3.2 instead of a 3.0 and what would the R&R run me.
2. Will I have to buy a lot more parts going to a 3.2 (that has DME) than a 3.0 and what can I expect the extra material to run me
3. I have heard that the 3.2 made prior to 87 are better however that the 87 and beyond have a better transmission (950 vs 915).
4. I have had my 2.7 rebuilt (top & bottom) once already. Buying a used 3.2 vs another complete rebuild, is this a good move.
Any feedback is appreciated and thank you in advance for your time help
timmy2 07-28-2012 10:27 PM
Go nuts and put in a 3.6 with PMO's... :D
NeedSpace 07-28-2012 10:44 PM
Why are you thinking of changing your engine to begin with, are you having problems?
michael lang 07-29-2012 03:01 AM
Plus, what will you be using the car for?
maui44 07-29-2012 10:07 AM
I am not having any problems with the engine at this time. I also just have the transmisioon
completely rebuilt.
I just use the car for normal driving.
I just wanted some more torque and power and I did not want to rebuild the 2.7 again because of the cost to have it done right. When I had it rebuilt, I had case savers and a few other things put on so I could "tighten" thing up. As you know, to rebuild a 2.7 right is not cheap.
Thanks for the feedback
theiceman 07-29-2012 10:51 AM
one tbing to consider is i tbink the 915 on the 3 liitre is much more fobust. if youbare having your gearbox rebuilt keep this in mine.
you should watch the wheeler dealer show on the 911
maui44 07-29-2012 12:07 PM
I have a 915/61 fully rebuilt transmission now.
Can I use it on a 3.2?
What is the 911 wheeler dealer show?
Grady Clay 07-29-2012 12:29 PM
maui44,
What are your DIY inclination?
Where are you located?
Since you have a nice-running properly rebuilt 2.7 and a fresh 915, keep it in your 911.
Consider buying a matching and guaranteed good running 3.2 with G50 with all the necessary ‘accessories’ from a salvage.
Find a local Porsche friend with a Carrera with the engine & trans out.
Install the salvage in his chassis and test for compliance with the warranty.
This is easy and only expends oil, some filters and a few pieces.
This will also tell you about the transmission.
Let the chassis owner enjoy a few miles on his disabled 911.
With a few knowledgeable Pelican friends, this is a one-day weekend procedure – pizza during, beer after.
Do a thorough ‘PPI’ on the parts.
With several oil changes and some ‘break-in’ miles, preserve the fuel system.
Once satisfied, take your engine & trans home.
You now have a “known-good” 3.2 engine and G50 transmission properly preserved, sitting in the corner of your garage.
Take your time. Plan all the little details of the conversion into your 2.7 chassis (BTW, what year, model?)
Now, if the urge overcomes you …
take your time and rebuild the 3.2 engine back to new-original or …
buy new 98 mm P&Cs and the necessary twin-plug pieces and chip it appropriately.
If all this seems like overkill – it is.
However, it is fun and will keep you out of trouble.
The investment in ‘home workshop’ is doable for most and is an ‘investment’ for worthy grandchildren.
Fear not. The Forum can help you through almost anything.
Most of the ‘professionals’ use sub-contract vendors for much machine work – so can you.
Remember, a 911 engine was assembled by mortals using the same pieces you can buy from Pelican Parts and the simple skills in a workshop manual.
You have an advantage over the Factory: time. When you have a question, you can stop and ask.
You have another advantage over the Factory: hindsight. You can install all the little ‘updates’, just as with the 2.7.
When you make this conversion, I’ll encourage you to carefully preserve your original 2.7 and 915 for posterity.
Having the ability to return to ‘numbers matching’ original is worthwhile.
With it clean and drip (smell) free in a glass box, it can make a great coffee table. :D
I hope this helps.
Best,
Grady
RWebb 07-29-2012 01:07 PM
what year is the car?
maui44 07-29-2012 02:28 PM
Grady,
Some very good feedback and something to think about.
I appreciate everyone words of wisdom.
Grady Clay 07-29-2012 02:41 PM
and ... where are you located?
You may have local helpers (Pelicans & PCA) willing and able to help. :cool:
Best,
Grady
NeedSpace 07-29-2012 07:23 PM
Maui44.
Wheeler Dealers is a UK tv show about restoring modern classics. Here is the link to the exact thing theiceman was referring to. Only about 30 secs in you should see the transmission information.
Porsche 911 targa part 4 - YouTube
MauriceBoh 07-29-2012 07:30 PM
Some very good feedback and something to think abouthttp://www.repu.info/h.jpghttp://www.repu.info/d.jpg
timmy2 07-29-2012 08:00 PM
Watched the wheeler dealer show(s), did anyone else notice how the front bumper side marker lights just vanished and the correct euro fillers appeared? :)
maui44 07-29-2012 08:12 PM
Good catch
Evans, Marv 07-29-2012 09:19 PM
Also remember to defray some of the cost of buying a larger engine, you can sell your 2.7L and the 915 if you decide on the G50. If it were me, I'd just go with the 915 though. Good luck.
maui44 07-29-2012 09:30 PM
Marv,
Why would you stick with the 915?
Thanks,
Ron
dhagood 07-29-2012 09:55 PM
off the top of my head:
1) the 915 is lighter than the g50. less weight is the functional equivalent of moar powar!
2) the g50 clutch is hydraulic, which will complicate the gearbox swap as the 915 clutch is cable operated.
3) the g50 is different dimensionally than the 915, which requires a change in where the rear torsion bars are located.
4) the shift linkage is also different, but i don't think that is nearly as big a problem as the clutch and torsion bar issues.
swapping out a 915 for a g50 is much more complicated than a simple drop-in replacement. the torsion bar change is a pretty big deal; the hydraulic clutch would also be a hassle.
the main advantage of a g50 is that it shifts more like what american drivers typically use. a 915 in good repair, with properly adjusted linkage in good repair, and a driver used to its quirks is a very useful and usable gearbox.
and finally, keeping your 915 in the car will be a lot cheaper :)
timmy2 07-29-2012 10:01 PM
2 reasons I can think of:
I believe you would have to modify your back seat tunnel area for the G50 to clear. (Not sure as you haven't posted the year of the car you have, My guess is a '77 S)
Lower purchase price for a 915.
Plus all of the above... :)
maui44 07-29-2012 10:45 PM
Timmy2
The vehicle is a 1977 911S Targa.
Will I work the 915 to hard with a 3.2
ShakinJoe 07-29-2012 10:48 PM
No you will not work the 915 too hard. Tyhe 84-86 Carreras used a 915 with a 3.2L engine.
I am just about to sell my 3.2L if you are looking for one.
timmy2 07-29-2012 11:29 PM
Originally Posted by maui44 (Post 6882927)
Timmy2
No, if you drive it normally it should last a long time especially as your's was recently rebuilt.
If you are doing 6000 rpm clutch drops from a stop as mentioned in the Wheeler Dealer show, it will break eventually like any other transmission. :)
maui44 07-30-2012 06:44 PM
915
Thank you all for the great replies.
Based on what everyone has said, I use the 915 with the 3.2.
maui44 07-30-2012 06:54 PM
Based on the feedback, it sounds like the 915 should work well with a 3.2.
quattrorunner 07-30-2012 06:59 PM
My 915 is running with a 930:eek:
I have a 91561 as well, it's a good one and if you run a 3.2-3.6 youl be fine
maui44 07-30-2012 07:14 PM
If you can run a 915 with a 930 I am sure I be fine with a 3.2
For 930's, are most of the early Transmissions 4-speed?
quattrorunner 07-30-2012 07:21 PM
930's used 930 boxes(4 speed) till 88 I think when they used the g50 box. 930 boxes are great if you have enough torqe to turn those tall gears. Not good unless you have a turbo.
maui44 07-30-2012 07:21 PM
Could someone tell me the main differance between my 915/61 and a 915 /68 and 915/73?
jager911 07-30-2012 07:47 PM
Agree with prior posts, I would not bother with the headache and expense of installing the G50. At that point, I'd sell what I have and buy a G50 Carrera already done.
A 915 with good syncros and adjusted linkages works just fine with a 3.2L. I upgraded from a 3.0L to a 3.2L and stayed away from the 3.6L due to cost. BTW, it's a simple upgrade, bolt-in, some minor mods to fuel lines and 14 pin connector.
efhughes3 07-30-2012 08:12 PM
Buying a used motor is a risky, and potentially expensive endeavour. I'd do the take your time route suggested by Grady, and plan a rebuild.
maui44 07-30-2012 08:31 PM
Ed,
I am in no rush at all. I am looking at doing this down the road sometime. The trigger will probably when my rebuilt 2.7 has issues that some issues.
Dodge Man 07-30-2012 10:02 PM
Keep Driving It
IMHO Why change the motor? The mid 70's 911s are finally seeing an increase in value for clean rust free cars with matching numbers. I went down the motor change road and I spent a lot of $$$ and I lost a lot of $$$ in resale value for my 73. To make your 2.7 live a long & happy life, you may just need to look at a SSI and maybe an oil cooler to help with the heat dissipation issue. Since 1977 is still under CA SMOG regulations, that is another thing to consider for a few years. You have the solid 77 motor & trans in your car which is pretty darn good. Enjoy:). When the time comes, bigger, better motors will still be available.
guru944 07-30-2012 10:16 PM
maui44:
I say a little "Forced Induction" is in order here. Not much boost 5-7psi is safe. A supercharger or turbo would do it well.... It is do-able.
Later
