Light bulb bingo mystery
This weekend I replaced the three bulb in my right rear tail light and replaced the rubber seal. Everything lit correctly when tested so I reassembled everything and went for a ride. Pulling into the garage and braking to a stop, an orange glow lit the front of my garage. I had my wife sit in the driver's seat and press the breaks. Yes, the front right turn light illuminates when the brakes are pressed! What the heck is that about?!?
Old 07-31-2012, 06:39 AM
Are you certain the grounds at the tail light housing are clean and secure? Don't know the year of your car but many cars have a ground wire that is connected to a bolt that secures part of the rear bumper.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 07-31-2012, 07:10 AM
My guess is that you've swapped the wires for the brake light and the indicator bulb in the rear housing. Or some other wiring permutation - open it up and double check. Did you check if the rear indicator bulb came on when you braked as well?
Mick
Old 07-31-2012, 07:20 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Putting the wrong base bulb in will cause lots of different problems.
Make sure the number bulb is the correct one (some have rotated contacts in relation to the pins that hold the bulb in).
Bob
Bob Hutson
Old 07-31-2012, 09:53 AM
j911brick's Avatar
I had a similarly strange problem and it turned out to be a short in the main wiring harness. But this kind of thing is rare.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 07-31-2012, 10:15 AM
