-   -   Engine problem (http://forums.pelicanparts.com/porsche-911-technical-forum/691839-engine-problem.html)
glennpenn 07-31-2012 04:55 AM
Engine problem
I have just put in new spark plugs and changed both fan belts in my 1976 911s, and have the following symptoms:
1. Engine running unstable and not using full potential on high RPM.
2. Engine is overheating (reaching 250 in short time when outside temperature is 20 celcius.
3. Low oil pressure
4. Engine suddenly shuts of when in low RPM (1000)
Does anybody recognize this symptoms?
Glenn
Chuck.H 07-31-2012 05:20 AM
it sounds like an ignition miss - are you sure the spark plug wires are in the right place? If the wires are old, they may be arc'ing to each other or to ground. Take a look at it idling in the dark to look for the arc's or (not for the timid) run your hands all over the wires as it's idling to feel the shocks.
Did you gap the plugs too far? This can cause mis-fires as well, as the spark finds an easier place to jump.
Chuck.H
'89 TurboLookTarga, 336k miles
schumicat 07-31-2012 05:36 AM
if it has cat I would check it for being partially clogged. also change fuel filter as clogged one could cause 1-2 of those symptoms.
SpeedracerIndy 07-31-2012 06:09 AM
Are you sure you tightened the fan belt properly? If it's reaching 250 that quick it might not be getting enough cooling air because of a slipping fan belt. A new belt might need to be set at a different number of shims in front off/behind the pulley half. You should have the same total number of shims though as with the old belt.
Ignigion problems could also cause high heat, poor performance. Chuck.H has some good advice above for ignition checks.
bassfishman 07-31-2012 10:35 AM
You have crossed spark plug wires. Re-check your firing order
