Always learning
Loud humming sound at startup
I'm absolutely miffed - there's a loud humming sound that lasts for a few minutes at startup on my 3.2. As you face the engine it's coming from the far RHS behind the air meter. Would it be in the vicinity of the oil cooler?
Any thoughts?
Old 07-29-2012, 06:07 AM
steely's Avatar
Just a WAG - dis-engaged, but running, starter?
Can't think of anything over there.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-29-2012, 06:32 AM
Northern Motorhead
wildcat077's Avatar
Just a thought here but how old is your fuel pump ?
They start to hum pretty loudly before they let go ... i know the sound would be coming
more from the front of the car but the vibrations can transmit and be misleading as to their
location.Mine did just that !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-29-2012, 07:03 AM
E Sully's Avatar
Ambient air valve located just above the oil filler neck.
Ed
1973.5 T
Old 07-29-2012, 09:26 AM
muck-raker
kidrock's Avatar
+1. Does it sound like a kazoo?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-29-2012, 12:44 PM
Always learning
Noise
Thanks for the replies
Ambient air valve. Ill check that out. Is that the one that is shaped like a mushroom? The whir sound is more mid range rather than high pitched.
Fuel pump is new although will check.
The sound is very loud in the cabin. Bordering extremely loud. Funny though because from the engine bay with the engine running, its only just audible. I might try the piece of hose to the ear trick tonight.
Could it be the oil pump? its the only item that I can think of that oscillates in that part of the engine area that could make such a sound.
R
Old 07-29-2012, 04:24 PM
muck-raker
kidrock's Avatar
yes
STONE
Old 07-30-2012, 01:54 PM
Always learning
Ambient air valve
Could I ask ,what dose this valve do?
Old 07-31-2012, 03:46 PM
muck-raker
kidrock's Avatar
Search, and ye shall find, my brother.
Ambient Air vlave question
STONE
Old 07-31-2012, 04:18 PM
steely's Avatar
I thought they brought in warm engine air to the TB for starting in cold weather.
I reckon it is winter there?
Dan
Venetian Blue
Old 07-31-2012, 04:20 PM
