advtracing's Avatar
sport purposes oil catch tank
I have been messing around to make a kit to suit the original design for a few on my cars , i test fitted the first one today in my 76s back date that is currently get a carb setup . looking close to the original drawing (refer photo) just need to complete the brackets correctly . will have a few extra to sell soon
"Funding my obsession one nut at a time"
-Purchased parts shipping to Carson, Ca
-Sold parts shipped from New zealand
https://www.facebook.com/john.gausden.31
Old 08-03-2012, 10:51 PM
Uno Dei Molti Porschisti
BarryJB's Avatar
Looks good, I'm interested! Will it fit cars with two-shock lids? Any baffle(s) inside between inny/outy? Have you tried it on 964/993 - my wrench says known breather oil puke problem with those if you fill past half-way on dipstick... he just uses a soda bottle on his track car
Cheers
Barry
85 Carrera Coupe, 3.6 conversion w/blah blah blah (a mod or two )ójust topped 400,000 miles! Mad Wasp (Benelli TnT 1130); 98 BMW K1200RS.
Old 08-03-2012, 11:20 PM
Registered turbo addict
Menmojo's Avatar
Catch Can
I'm interested in one of these for my 73 track car.
It would sure look better than the old brake fluid can I've been using!
Please PM when you have one available......
Old 08-06-2012, 12:26 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
I suspect the right hose goes to the tank. Where does the left hose go?
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 08-06-2012, 12:38 PM
air+fuel+spark
combatic's Avatar
Interesting! Can you take some wide shots of the setup so we can see how the lines are routed? I am guessing the left hose goes to the case breather?
sub'd
bryan
1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle
R Gruppe #653
Old 08-06-2012, 12:48 PM
advtracing's Avatar
hi guys the rhs goes to the engine case breather and the right hand side to the oil tank . this can vary a bit if you have a 72 or different oil tank set up.
The unit also needs to breathe so there is no pressure in the case , so the cap will be either off or drilled in the centre .
i will do a full set of photos once i have the carbs mounted on this car and everything set up . the units should be available in above 5 weeks , i'll advise on this thread
Old 08-06-2012, 07:48 PM
advtracing's Avatar
made a few of these up , and they all sold , so making a few more for next month if anyone wants a kit
Old 09-20-2014, 04:42 PM
Elombard's Avatar
I would like one.
Erik L.
erik.lombard@gmail.com
84 lime green back date (LWB 911R with RS rear flares) hot rod - absolute riot to drive!
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-20-2014, 06:11 PM
sc_rufctr's Avatar
Yours is a Great looking kit.
Here's a pic from an original SCRS for reference.
Peter
Old 09-20-2014, 06:23 PM
advtracing's Avatar
cool , another project i am doing is the scrs air box fronts with mesh , made to fit 71-73 MFI air boxes . should have the first one popped out in 2 weeks
Old 09-20-2014, 06:40 PM
Revise the oil path.
High velocity blowby exits the crankcase breather. Thus, like the factory setup, this hose should first connect to the oil tank which helps separate most of the oil from crankcase pressure.
From the tank, another large hose leads to the catch can for additional oil/air separation. The other catch can hose leads to either a breather, then to atmosphere or simply provides a path to the intake tract to reburn. Careful about venting to atmospheric. There may be situations (e.g. high G loads, excessive blowby, etc.) that may cause the tank to fill to capacity and/or the engine to puke a larger-than-normal volume. This could result in liquid lube exiting near the RR tire and a wild ride.
Sherwood
Old 09-20-2014, 09:08 PM
advtracing's Avatar
The first one i made has been in a street / race car for the last 2 years , no issue what ever , just a little oil caught as it should .
The 2nd one in a rsr rep road car 1 year , again no issue
Old 09-20-2014, 10:05 PM
ROW '78 911 Targa
timmy2's Avatar
I'm interested, pm me with information please.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-20-2014, 10:44 PM
Hi John,
I wish I had have seen your thread a couple of days ago, I just had an oil catch can shortened to fit in the engine bay.
Cheers,
Harry.
Old 09-21-2014, 12:43 AM
Elombard's Avatar
Yeah to expand on what sherwood said I thought the whole point of a catch can was to eliminate the hose from returning the oil fumes to the intake. The fumes contaminate the air fuel mixture and lower performance. I thought I noticed a marked difference when I added a catch can and plugged the fume return on a tired 3.0 CIS motor. The more tired the motor the more blow by and the more contamination.
Erik L.
Old 09-21-2014, 04:24 AM
advtracing's Avatar
with the case breather to the catch tank and the oil filler breather to the catch tank we have no return to the intake and engine works better .
4 left
Old 10-04-2014, 05:13 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
How much, very interested
Old 10-04-2014, 05:23 PM
advtracing's Avatar
OK , so i have been asked and asked to do a single entry verson rather then just what i have made to date ...Sooooo i have 4 left that i haven't already fitted out . Not a lot in cost saving but made to order only . approx 2 weeks turn around to shipping.
Old 10-06-2014, 08:25 PM
irl irl is offline
irl's Avatar
PM sent
Old 10-07-2014, 06:38 AM
irl irl is offline
irl's Avatar
$ sent for a one one version.
Eddie from Baltimore
74 911 under construction searching for its new identity
75 911 backdated RSR widebody on its way
71 911T running sweet
63 356 outlaw frustrating purists
Old 10-07-2014, 06:47 AM
