Speedo slow to start
Hi guys
So the speedo in my 84 started taking its time to start moving. It starts to move when i get to @ 25 miles per hr then its fine.
Any ideas?
Old 08-28-2012, 07:04 PM
RETIRED
Joe Bob's Avatar
Might consider taking it to a speedo shop. Could need a rebuild. Palo Alto and North Hollywood Speedometer do good work on our cars. Call them describe the symptoms.
2012 ML350 3.0 Turbo Diesel
Old 08-28-2012, 07:21 PM
Reiver
Reiver's Avatar
Try taking it out and cleaning the electrical contact surfaces...had the same issue at low speeds...had to tap the glass.....just dirty connections in my case.
Old 08-28-2012, 08:34 PM
Had it done at hollywood a couple of years ago.
I'm gonna try the contacts
Old 08-28-2012, 09:27 PM
Dublinoh's Avatar
If no joy, the sending unit is activated by magnets. I read a thread that recommended pulling the sending unit and cleaning the magnets with a Q-tip, and carefully reinstalling the sending unit so it can correctly interact with the magnets.
Old 08-29-2012, 07:24 AM
^^^ +1
I had the same problem 2 years ago and cleaning the magnets fixed it. Need to clean any scum off the sensor and the magnets which are seated in the transmission. Should be the first thing to try, and best of all its free.
Chris
'87 Targa
Old 08-29-2012, 08:06 AM
At first try if it starts moving below 25 MPH if you tap the glass or knock on the top of the dash. If it does, then it's either the electrical connections or dirt build up inside of the speedo. Mine is doing it right now and is on the list for my winter projects. If tapping it doesn't help, then it might be down by the transmission.
Juergen
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 08-29-2012, 08:24 AM
gearhead
I've got the same problem. I've just been too lazy to pull the thing out and clean it.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-29-2012, 09:08 AM
Brorag
Brorag's Avatar
similar problem on '87--
when I first run the car, the first 3 miles the speedo doesn't register, then it heals itself. Don't know if mechanical or electrical--tach ok--wonder if the same issue or something different?
Old 08-29-2012, 10:06 AM
dshepp806's Avatar
Get the thing shipped out to the pros for a refurb (NHW speedo) ,..especially those aged electrolytic caps within the circuit.....get a fresh calibration, as well....
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-29-2012, 02:31 PM
