1969 911
I am buyining a 1969 911 and found out when I went to pick it up that the original trans had been lost, it was a 915A four speed. It now has a later 915 5 speed. The trans and engine are out as well as the axles. I have a 1972 911 I'm working on. will the axles from a '72 fit this setup? My plan is to take the axles out and see if they fit the trans, I'm sure it will but I dont know if it will slide into the wheel side or if the lenght will be correct.
please help as I burned a hundred dollors going out with my trailer and he allowed that I can research before I take delivery.
Old 08-06-2012, 11:14 AM
Mike,
The '69 would have come with a 901 gearbox originally.
The 915 gearbox should bolt-in without issue. Depending on the clutch arrangement there may be a combination of parts to ensure it works properly. Not a major issue though.
Axles should be interchangable between the '69 and '72 both with length, flange and drive stub. Proof positive - from our host the same axle is specified from 69-73. The 901 was used through '71 and the 915 thereafter.
Chet
Chet Dawes
1971 Porsche 911T Coupe
1974 Porsche 914 2.0L
2004 BMW 330i ZHP Sedan
2008 BMW X5 4.8i Sport
Old 08-06-2012, 11:33 AM
