-   -   engine padding adhesive (http://forums.pelicanparts.com/porsche-911-technical-forum/692759-engine-padding-adhesive.html)
chhdskk1 08-05-2012 01:11 PM
what would be a good engine padding ahesive to apply, for a 1986 carrera ? replacing engine sound padding, thanks ,,
RSTarga 08-05-2012 01:14 PM
The best way to do this is magnets. You'll avoid the dreaded glue and disintegrating foam problems.
Someone described the procedure here so do a search. Basically you just glue some of those thin high powered magnets to the pad and your good to go.
