-   -   Pertronix Ignitor (http://forums.pelicanparts.com/porsche-911-technical-forum/6928-pertronix-ignitor.html)
wslynn67 08-08-2001 06:15 AM
Pertronix Ignitor
I would like to relate a good experience with the Pertronix Ignitor.
I have had to fiddle with my car constantly over the last 20 months I've had it. I would set the points, the cam follower would wear down, the gap would change, and the car would run poorly, expecially at high rpms. Then I would have to reset everything again.
Since I replaced the points with this electronic unit, the car has run better than it has at any point since I've had it. Installation was fairly easy as well and I'm not in a constant battle with the feeler gauge and screwdriver.
My 1 cent (haven't had the car long enough to have 2 cents worth of advice).
Scott Lynn
1971 911e
Early_S_Man 08-08-2001 06:55 AM
That is good news that you have had a good experience with them. I have never had any problems with my distributor using OEM Bosch points and keeping the distributor cam lubricated with Bosch grease. Yours may have become pitted due to rust over the years due to neglect by a previous owner!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
