-   -   Left turn sinal problem (http://forums.pelicanparts.com/porsche-911-technical-forum/692813-left-turn-sinal-problem.html)
quattrorunner 08-05-2012 05:29 PM
So I had my rear bumper off for an engine drop, and the engine and harness had gone through some drama for about two months before it was all put back together. When it was back together, I didn't have front left signal. Neither hazard nor indicator. The dash light shows very light dim lighting of both left and right when left signal is selected. Right signal is normal. Any ideas?
quattrorunner 08-05-2012 09:02 PM
bumper
timmy2 08-05-2012 10:59 PM
Check your ground point for the rear and front signals. Also take a look at your wiring and fuses where the turn signal is fed from. Could be a failing or loose fuse or wire connection screw is loose.
