-   -   Please Identify (http://forums.pelicanparts.com/porsche-911-technical-forum/69311-please-identify.html)
partyparty 05-22-2002 04:11 PM
Please Identify
I found these in the trunk of my 69 Targa. what kind of tools are these and what are they worth. I know one is a lug nut remover. are these original porsche tools? The other tool which has a curve has a number it "P208" http://forums.pelicanparts.com/uploads/Img00068.JPG http://forums.pelicanparts.com/uploads/Img00070.JPG http://forums.pelicanparts.com/uploads/Img00071.JPG http://forums.pelicanparts.com/uploads/Img00072.JPG http://forums.pelicanparts.com/uploads/Img00073.JPG
Early_S_Man 05-22-2002 04:24 PM
#1 is the spanner for holding the alternator fan pulley while loosening/tightening the nut to remove/install a fan belt!
#2 is a Klein 21 mm spark plug tool ... a 10 mm hex key is used in the knurled end to apply torque to do the initial loosening and final tightening ... finger power on the knurled section allows easy spark plug removal and installation! <b>BEST tool ever put in a 911 tool kit!!! Please DON'T attempt to use it on your 19 mm lug nuts ... or oil drain plugs!</b>
partyparty 05-22-2002 04:35 PM
I don't think I will be using it on my lug nuts LOL
