Yoko Advan Neova AD08 noise - anyone with experience?
I just had a bunch of suspension work done on my '88 and replaced the tires in the process. I put a set of Yoko AD08's on it. I also got new shocks/struts, turbo tie rods, euro ride height, inner/outer CV boots, front/rear neatrix bushings, and alignment.
With the new tires, they start to make some pretty loud tread noise at 45, and then really resonate from 65-75. I mean, with the windows up, it sounds like I'm driving a train. I haven't tried anything past 75 on the highway due to VA's draconian speeding laws. However, I'm wondering if anyone has these tires and has experienced similar noise, or if I should start looking elsewhere. (Alignment, rear wheel bearings, CV's)? If there's a chance that the alignment specs have anything to do with it, these are the alignment numbers: Camber LF= -.1' RF= -.08' LR= -1.15 RR= -1.17 Caster LF= 6.12' RF= 5.57' Toe LF= 0.06 RF= 0.06' LR= 0.1' RR= 0.1' SAI LF= 10.54' LR= 11.07' Rear Total Toe 0.2' Rear Thrust Angle 0.0
-Ethan Last edited by ejp; 08-07-2012 at 05:32 PM.. |
In my experience these are the noisiest tires ever made
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
I have Toyo R888's. These tires make as much noise as off road tires. I would guess the noise in your case may be normal.
80 911 SC 06 Z71 Tahoe |
deRegistered User
mileage on the tires?
When you reduce the vehicle weight, “you get more performance with less of everything.” – Alois Ruf, quoted in THE ESSES (Early 911S Registry Bulletin) Fall 2005, 15(3): 3. |
At this point, ~200 miles. Do you think that I can expect them to quiet down after a certain point?
-Ethan |
deRegistered User
not much more
beancounter
I am on my 2nd set of AD08s. I can't say I have noticed hearing excessive tire noise compared to my other cars. That said, the 930 is just a noisier driving experience in general vs. the newer vehicles in the stable.
Jacob 1979 930 - Minerva Blue 2012 CTS-V Wagon |
- Arne 1984 Chiffon White Coupe - Wong chip, Seine GSK Pics and story at http://84-carrera.home.comcast.net (not a clickable link, copy and paste) The other car - 2010 VW Golf TDI |
deRegistered User
could possibly be noisier until broken in
you will need to buy spendy tires where all factors are optimized
![]() Oh well - this means that I will need to spend more time on the track to burn through these ![]()
-Ethan |
I had AD08's on my 81 SC. Maybe because I didn't have the windows up in the Fall and Spring, but I never noticed any excessive noise. What I did notice was razor sharp response, and fantastic grip. That having been said, I moved on to an 84 Carrera with Bridgestone RE-11s. They are not quite as responsive, but definitely ride better and stick like glue.
I would be happy to have either on my car. |
*sigh* ![]()
-Ethan |
Long update on this thread for anyone who searches for Yoko AD08's. After a decent alignment, they have quieted down and are actually quite usable on the street. They're still noisy, but nothing like the noise that I was experiencing when I posted first posted my question. I would consider buying these tires again.
-Ethan |
ɹoʇɐɹǝpoɯ
I had A032's and A048's. So noisy you think your bearings must be shot.
Jack Olsen 1972 911 A pretty slick video about my 911 and its garage • The website for that garage |
![]() I tightened them every weekend for a few months, and consistently found play after a few days...until I finally replaced the bearings to save the spindles. The AD08's are a little noisy, but I consider them a streetable summer tire by all means. They're squirley in cold weather, but there is no reason to fault a summer tire for this, they're *summer* tires. I consider the squirreliness to be added-fun.
-Ethan |
