Porchcar guy's Avatar
E-Brake adjustment
My e-brake works, but only holds the car at the top of it's pull. I would like to adjust it to hold a few clicks from the top. Is there an adjustment on the cable to tighten the pull or do I need to go into the rear brakes to turn the cogs ? Thanks in advance for any insights !! I will look at Wayne's book tonight to see if that helps.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 08-07-2012, 11:16 AM
Cooper911SC's Avatar
You need to adjust the shoes at the rear.
When the handle is lifted the brakes should drag at about 3 clicks up and be fully engaged at 5 clicks.
It is a little challenging to locate the star wheel through the hole in the rear brake.
Good luck with your adjustment.
Cooper
Old 08-07-2012, 12:00 PM
schumicat's Avatar
Wayne's book has the whole adjustment procedure as does the host website tech info section. the cables can be adjusted to take up excess slack and make it pull tighter, but it is a blunt tool and a proper adjustment also uses the star adjuster (cog).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-07-2012, 12:31 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by schumicat View Post
... and a proper adjustment also uses the star adjuster (cog).
+ 1. Bentley also show it. It maybe be hard to visualize how the star adjuster work but it you take the drum off and look (and play with it) it will help.
Who Will Live... Will See
Old 08-07-2012, 06:58 PM
