RETIRED
Joe Bob's Avatar
Carrera cooler repair
So I noticed a steady drip from under my passenger front fender. Looks like a leak.....pulled the wheel, broke loose the connection from the Elephant line to the cooler and the divert to my cooler in the nose....gave a clean up and re-tightened.
Took it for s serious jaunt.....still leaks, Fookkkk.....
Looked closer and it looked like the body of the cooler and not the lines or fittngs.
Pulled the cooler, stripped the rock guard off, the fan, and took to a local radiator shop. They found a pinhole leak inside the flap of the lower....mount.
Never seen this happen. BIG weld bead, pressure check to 135psi and no leak.
2012 ML350 3.0 Turbo Diesel
Old 06-11-2012, 04:28 PM
RETIRED
Joe Bob's Avatar
Old 06-11-2012, 04:33 PM
RETIRED
Joe Bob's Avatar
Got it installed, took it out on a hard run today.....stopped in the drive, dry as a bone.
Checked the oil level gauge....nothing. Dip stick was dry, had to top it off with two quarts. I lost more than I thought with the leak and the loss when I pulled the cooler. Filled it to just below 1/2 way up the dipstick.
Nice to be able to fix stuff by yourself and a little help for the radiator guy. $85 for the diagnosis test, degrease, repair and pressure check. 2 quarts @ 2.49 each of VR1 20-50 Racing dino oil.
Lot better than $500 for a new BEHR cooler.
Old 06-13-2012, 10:59 PM
muck-raker
kidrock's Avatar
way to go, JB. I love a cheap fix. Thanks for posting this, it's nice to know we have these kind of options.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 06-14-2012, 05:48 PM
RETIRED
Joe Bob's Avatar
Thanks.....messy job.
Old 06-15-2012, 06:24 AM
The Dude abides...
bigel's Avatar
The cooler likely holds a little under 2 qts of oil itself, right?
Where'd you find VR1 for $2.49/qt.?!
Oh and a, nice bedspread/slipcover...
'03 Carrera 4S
Old 06-15-2012, 07:26 AM
RETIRED
Joe Bob's Avatar
The cooler holds about 1 quart.....I'm thinking the leak did the rest.
VR-1 goes on sale for 2 bucks off every year at AZ and Kragen/O'Reilly's in the spring. I picked up 2 cases.
Old 06-15-2012, 07:41 AM
RETIRED
Joe Bob's Avatar
Close up on the repair.
Old 06-15-2012, 07:53 AM
Always learning
Hey joe
Great to see the cooler shares the same bed as you! We all love our Porsches here but is that taking it a little too far?
Hehehehehe
Old 08-08-2012, 04:24 PM
RETIRED
Joe Bob's Avatar
Oil cooler, my dog and a good book....
Old 08-08-2012, 07:03 PM
