help decoding engine number
hi ,
still need a little more clarification so bear with me please....i am looking at the purchase of a motor, can anyone help with the id?do targas have different numbers from coupe? i know sportos do etc. the stamped number on the case is 6117***...is this a targa or coupe block ? i see 2 different references and of course they differ. ben |
for a 1971 911T the engine could be one of 4 different types, and totally independent of body type. Basically either USA or ROW (Rest Of World), and manual or sportomatic; so two versions for each market. Any of the four types could be in a coupe, a Targa or a Karmann coupe; the body type does not matter.
According to my reference, you will not be able to tell from the engine number is the block was specific to a coupe or a targa as both body styles used engines from the same number range.
how would you be able to to tell if a block was within the range of the build on a certain car..did porsche put casting dates on blocks..the block i am looking at numerically has a 300 or so difference from my block (later/larger numbering). could/would it still be correct for my car? thanks , ben
probably be easier to track if you had the 2 threads about the same thing in just one thread...Just sayin...if the highest number is 6118119 and yours is 6117**** doesn't it make sense that it is in your series ?
wouldn't the block with the higher number be built after the block with the lower number...are there casting numbers located on the blockthat would be cross reference to the vin? |
thanks to all for your time and info...thread closed. ben |
| All times are GMT -8. The time now is 09:30 AM. |
