Dropped ROW 3.2 engine rebuiling trans + "while in there"
So today I decided to remove my ROW 3.2 Engine and transmission from my SC,
After developing some problems with my transmission Where my 1st gear would no longer engage I knew there was trouble in paradise. I contemplated switching to a 923 (7:31 ring pinion transmission) but quickly abandoned the idea As posted on this thread----> http://forums.pelicanparts.com/porsche-911-technical-forum/693056-who-has-done-923-transmission-912e-7-31-conversion-im-about.html Now its back to the 915 transmission http://i60.photobucket.com/albums/h3...C/f073bb0e.jpg I Always forget how much fun it is to remove Older 3.2 engines ! I spent 3 days studying the 101 Porsche Projects book our host wrote (such and awesome book and highly recommended, I have 3 copies for different rooms) <a href="http://media.photobucket.com/image/101 porsche projects/cmdrtaco/Porsche 912/101ProjectsforyourPorsche-Dempsey.jpg?o=0" target="_blank"><img src="http://i628.photobucket.com/albums/uu5/cmdrtaco/Porsche%20912/101ProjectsforyourPorsche-Dempsey.jpg" border="0"></a> ----> Pelican Parts - Product Information: BK-131569AP So after paging the book for a few days (in the bathroom, during breaks, during lunch and at night in bed ) I pretty much had it all fresh in my memory. Every single item came out with out a hitch (other than a rusty exhaust clamp) I found some ugly stuff while digging around Ugly drop links bad sway bar bushing Question able motor mounts Questionable rear shocks Various lines to replaces the list goes on http://i60.photobucket.com/albums/h3...C/23dbc873.jpg To make life easier the Turbo style decklid was removed and most likely not returning to the Chassis ! A Duck tail will take it's place Something very disturbing I found was a ruptured intake boot! It has two holes in different spots! yikes not good If someone has one let me now... Other wise I may have to go bug my old boss at LA Porsche http://i60.photobucket.com/albums/h3...C/ecc4784b.jpg Engine was a little dusty.... Ok ALOT of dusty!!!! I will have to clean (pressure wash it! before it goes back in) Engine only has 85k miles on it ! If any one has any ideas of lil project to do please chime in: Thermostat housing seal being replaced Valves already adjusted New rear mail seal already installed http://i60.photobucket.com/albums/h3...C/7e72760d.jpg One thing that did not make me too happy was the flywheel it self! It looked glazed and felt wavy like an old brake rotor!.... time to replace??? All fuel lines felt nice and soft no cracks on the that I could see http://i60.photobucket.com/albums/h3...C/912c3fec.jpg http://i60.photobucket.com/albums/h3...C/614cf5dc.jpg The 915 Transmission looked pretty nice from the outside (other than being dusty) No Oil leaks on the Engine or transmission that was a big plus looks like this guy will come apart tomorrow Going to rebuild the Axles purchased gasket/seal kit I found 5 very small teeth in the blue Swepco oil I used a painters paint filter to find any traces of shrapnel in the oil... luckily everything was fine and only found evidence of carnage in the magnetic drain plug. http://i60.photobucket.com/albums/h3...C/7a5011ef.jpg The engine and transmission mounts look ok but I made a quick call over to Clint Rebel Racing Products Link----> Home to order his Engine/transmission mounts ! As usual He was very helpful and quick with the order. I'm very exited to install these on to my car I think they will make a huge difference in feel. I also picked up some Bilstein Sport rear shocks to go with the Bilstein front Sport inserts I got from Rebel Racing previously. Now moving on to more troubles This Throw out bearing below has some serious play!!!! Is this normal ? moves quarter of an inch in either direction (up/down) purchased new a few hundred miles ago the transmission would make noise when I would not press the clutch in Like a chatter very very annoying the clutch plate had even wear through out so I don't think anything was warped http://i60.photobucket.com/albums/h3...C/393cd5d0.jpg The underbelly of the engine bay!!! Looks like I need new heater tubes and a Serious steam clean http://i60.photobucket.com/albums/h3...C/dabc2d2c.jpg More photos coming soon -Steam cleaning before/after shots - Full transmission rebuild shots (process) -replacement Bilstein shocks -engine upgrades and leak down test - Rebel Racing engine mount instal - engine/trans install If you guys have any tips or suggestion please help out a newbie |
Looks like big fun! On a few of your questions -
The flywheel can be turned like a brake rotor, and sounds like it should be, as long as it's within tolerance. If I recall correctly a little lateral play in the throwout bearing is normal. Your chattering might have more to do with the condition of the flywheel, or possibly cable adjustment issues. I think I have one of those intake boots in good shape. What's the part number? PM me for details. You doing the transmission yourself? I'm sure you know the Peter Zimmerman wiki/tutorial. I did a 911 (late 901) transmission a couple years back, and enjoyed the challenge. Good luck! Mike |
Nice job so far.
All I can say after looking at your photos is....Start by cleaning. Then continue cleaning. And when you are done, clean some more. :) Nice car, but filthy engine/trans and engine compartment. If I did this(and I am lazy), then so can you. Please keep us posted. This is a neat project. |
Thanks for the comments
Hi Bill, I didn't look into Overhauling ! didn't even cross my mind I just ordered new ones from Rebel Racing I will see if I can sell the ones off my chassis, maybe someone wants to rebuild them. I never heard of anyone rebuilding them, that is pretty interesting mcaterino/ Mike I'm hoping the flywheel can still be turned I've never done it, might have to take it to a shop or something... ? The cheapest new flywheel I could find (84-86) was close to $400 The cable for the clutch looked fairly new ...maybe clutch adjustment! the part number for the intake boot is 930.110.356.02 I figured If I couldn't find one easily I would just glue it and JP weld it ??? the Transmission is being rebuilt by my self (as a learning apprentice) guided by a well known Porsche Tuner who has all the items necessary for a full rebuild + special tools. He tells me its a full days labor to do it I will document the whole thing... maybe a youtube video and photos for sure. I'm crossing my fingers that I only need minimal parts CCM911 TOTALLY Agree with you The engine compartment is FILTHY I spayed the engine with PB Blaster Citrus degreaser and Yep aerosol It was really cleaning up nice I was very surprised how clean it was under the muck. I plan to Steam clean the engine compartment for the most part is cleaning up well! I'm trying to close my eyes about "while I'm there" parts to buy since I'm extremely low on cash... http://i60.photobucket.com/albums/h3...C/2eef6b50.jpg This Is the Engine compartment after cleaning it with a Rag and some Zep Spray... I think the steam cleaner will really make this look nice and fresh Planning to take apart the fuse panel and make it nice and legit. New Fuel Filter New hood shocks Clean up some wire http://i60.photobucket.com/albums/h3...C/06e22e1c.jpg This car needs new Heater box accordions Maybe get some from home depot ??? or something hahahahah suggestions ? Looks like it needs some new engine surround plastic... but short on change Wonder if 964 will work ??? I got spares of those Need some engine Sound detaining--- I might cut up some 964 Sound detaining I have in new condition Need to remove the Charcoal canister since its not being used Its just kinda hanging there from previous engine build Dead weight http://i60.photobucket.com/albums/h3...C/b7228f5f.jpg What really has to go is the Cabriolet Engine support mount with shock any one want to trade for a solid ??? Or want to buy it so I can get a Solid one http://i60.photobucket.com/albums/h3...C/ec1746e1.jpg http://i60.photobucket.com/albums/h3...C/5c8a34a2.jpg (before cleaning) http://i60.photobucket.com/albums/h3...C/08ce4580.jpg This is the Ugly Flywheel looks like New flywheel bolts coming soon http://i60.photobucket.com/albums/h3...C/67f1eeed.jpg After a minute of simple PB blaster Citrus cleaner and light rubbing This is gonna clean up very nice http://i60.photobucket.com/albums/h3...C/b9a4aa53.jpg Got the Ultrasonic cleaner out.... added some degreaser in the mix and the parts are coming out super clean n http://i60.photobucket.com/albums/h3...C/d96faa42.jpg This is the 915 Taking a bath ... It cleaned out pretty nice I barely washed it and scrubbed it. Thank goodness I have a parts cleaner I'm hoping it looks like new after I get it all rebuilt http://i60.photobucket.com/albums/h3...C/ec352fc1.jpg SO HERE IS A BAD SIGN!!!! It seems the nose cone has been removed already ! I found some non factory sealant and the bolts upfront looked like they had been removed Maybe this is why it was shifting funny....bad job ? Total bummer, I will post what I find Any suggestions would be awesome This is gonna be a fun project |
Oh yeah this is the transmission mount
I'm gonna sand blast it shortly then a quick spray paint http://i60.photobucket.com/albums/h3...C/45e7dad4.jpg http://i60.photobucket.com/albums/h3...C/c31945f7.jpg |
The boot I have is 930.110.358.05. Not sure if it makes a difference or not. You can do a little research to see, and let me know.
Mike |
That is one well stocked garage. I wished I have the room and a parts cleaner.
How do you like that ultrasonic parts cleaner? What model and what was the price?
Good luck with your transmission repair. |
mcaterino seems like that is for an SC
I need one for a Carrera I think I will fit mine ..super glue and JB weld. At least until I can afford to buy a new one, my project bill keeps going up Like willy wonkas glass elevator yelcab1 My boss was kind enough to let me borrow the tools and lift kodioneill The ultrasonic is nice It cleans parts really well Not sure of the model need to double check... Craigslist had a few I picked this one. Bare in mind the Ultrasonic cleaner pictured is pretty small... only for hardware and small pieces...looks big in the photos I'm currently waiting to hear back from my friend about my Transmission Said he would be free later today and tomorrow so I could tackle it More photos of the build coming .....well once it gets done |
The Story of my Engine drop/ Trans rebuild continues
Sunday was the day I was finally able to get into my transmission and start the rebuild process. It was a very hot steamy California summer day, I had woken up at 4am so I could make it over to the world famous Pomona VW/Porsche Swapmeet.Arrived at 5am, I didn't score too many items so the day was already kinda dry. I left by 8:30am with a Ducktail, Tail lights, Some minor parts, emblems and 70 pounds of Legos! I was hoping to score another tranny, maybe a flywheel and parts for some members who requested items. NO LUCK It was kind of a Dry day due to the Hot hot weather I made my way out to my friends shop after a short nap and some food... Pulled the ultra clean tranny that I had shrinked wrapped out of my friends borrowed car.... FINALLY ITS TRANSMISSION REBUILD TIME The tranny came apart fairly easy We cleaned a table added some diaper absorbent rags Got the 13mm tools out and worked my way in... This is the first thing we saw!!!!! HORROR NOT FOR THE WEAK OF HEART http://i60.photobucket.com/albums/h3...g/1c546855.gif I though I only saw Freddy Kruger in nightmares http://i60.photobucket.com/albums/h3...C/51b4559e.jpg AAHHHHHHH http://i60.photobucket.com/albums/h3...C/e22f1d4b.jpg That's right the Synchro Ring was demolished and stuck in the case! (I guess that's why it wouldn't shift to first) Below is another angle of it http://i60.photobucket.com/albums/h3...C/922a1e8a.jpg This is what I ended up pulling out of the front box YIKES!!! this is very scary http://i60.photobucket.com/albums/h3...C/89ba030a.jpg A little peak below and what did I see http://i60.photobucket.com/albums/h3...C/2134e592.jpg Rocky Balboa himself couldn't knock this many teeth out a little more removal (sorry about the pic) http://i60.photobucket.com/albums/h3...C/82f4b023.jpg As this point I has towels and was picking up all the particles of metal. Notice the teeth hanging on the case http://i60.photobucket.com/albums/h3...C/f1806cf1.jpg The little cover (window) was also covered in metal bits http://i60.photobucket.com/albums/h3...C/2bbc8760.jpg Doing my best to keep items organized |
Then we dug into the next part of the Case!
http://i60.photobucket.com/albums/h3...C/154319ce.jpg More damage! http://i60.photobucket.com/albums/h3...C/b5e058be.jpg http://i60.photobucket.com/albums/h3...C/2134e592.jpg The Slider was beyond useable ...totally munched out...gone! http://i60.photobucket.com/albums/h3...C/c5d25d33.jpg http://i60.photobucket.com/albums/h3...C/1cd85b41.jpg side by side with another one of my Transmissions villians http://i60.photobucket.com/albums/h3...C/6ca2067b.jpg Some cleaning and further inspecting http://i60.photobucket.com/albums/h3...C/a73d8d13.jpg Next was the Differential side cover where I knew I would find more teeth but not only did I find teeth http://i60.photobucket.com/albums/h3...C/3caeba5c.jpg Found gear brakes and various more pieces shrapnel ahhhhhhh (sorry about the photo) http://i60.photobucket.com/albums/h3...C/03bd0147.jpg The Differential looks ok but will need to be cleaned very thoroughly http://i60.photobucket.com/albums/h3...C/e3be1ac7.jpg I Wish I had an LSD but can't afford one right now....and I don't know of anyone selling one... (very low budget) |
digging deeper
http://i60.photobucket.com/albums/h3...C/406dce8b.jpg http://i60.photobucket.com/albums/h3...C/ef539f14.jpg The Parts spread http://i60.photobucket.com/albums/h3...C/55a2174d.jpg http://i60.photobucket.com/albums/h3...C/cab9178e.jpg Before and after http://i60.photobucket.com/albums/h3...C/f7879953.jpg The Verdict: I GOT VERY VERY LUCKY My Transmission really only needed 4 major items 1st gear Synchro ring 1st Gear teeth brake gear a slider Reserve gear Gasket kit all other gears and items looks great! and very useable No crazy damage or bent items I was out of the critical condition room!!!!! I was told that I should consider replacing my 2nd gear in the next year or so... I won't be selling 915 transmissions any know...you can bet on that I was lucky to have a friend with all the items laying around... granted I still owe him. He has been one of the coolest persons I've ever dealt with in the Porsche world so Unselfish.... but he chooses to remain anonymous so I'll respect that. We will be finishing the Job most likely tomorrow. Still todo: ADD a 915 factory Oil cooler Machine the center case for the oil cooler boss parts wash the internals of the case actually put it back together again switching transmission oils... no more swepco... any one want a bottle ? Today: I sourced some other items for my Trans My biggest Score Today (Monday) came when Dave at TRE provided me with a Excellent condition used 84-86 Flywheel (very specific) I took my flywheel for him to look at while we made deal on other items I was wondering if it could be resurfaced. He said: "NO way that thing is long gone" At this point my heart dropped knowing I would have to spend $400 (that I don't have) for a new flywheel. He Then told me to wait a moment and off eh went into his parts room he emerged a few minutes later a excellent good used spare flywheel that he just happen to have. (these flywheels aren't easy to come by) I was glad I took a drive over to his place, for other items not expecting to do anything about my flywheel. He has came through time and time again definitely on my "Best people/shop list" I will post a picture tomorrow of the flywheels side by side as well as photos of the build So far so good |
No photos of the Tranny work today
Other than it was inspected ..... What I did get done was Sandblasting the Transmission mount gonna paint them shortly http://i60.photobucket.com/albums/h3...C/ab2d5dd3.jpg http://i60.photobucket.com/albums/h3...C/795de6f8.jpg and a BIG surprise Clint at Rebel Racing Sent over a set of Bilstein Rear Sport shocks And some of his Newest Engine Transmission mounts Check out the eye candy http://i60.photobucket.com/albums/h3...C/586c4305.jpg http://i60.photobucket.com/albums/h3...C/40231635.jpg http://i60.photobucket.com/albums/h3...C/d1fa655a.jpg these will go nicely with the engine install The more I look at the car the more projects I see SS Brake lines from Rebel racing New Rear Rotors New rear brake pads New E-brake shoes Fuel filter change (might as well) Bushing for the sway bar Drop links (mine are cracking) Oh yeah a Duck tail! I got this from a Fellow Pelican member who said he purchased it from TRE The quality looks really good but it's a bit heavy compare to my other Duck tails http://i60.photobucket.com/albums/h3...C/937e3a5e.jpg Its not bolted on just hanging |
Transmission was finished today!
http://i60.photobucket.com/albums/h3...C/d2800c14.jpg http://i60.photobucket.com/albums/h3...C/b01aa4f4.jpg I will update some more photos later Items that needed replacing Shifter Sleeve Guide Sleeve Shifting gear Reverse Idler 1st Synchro Hub (3) Synchros Barricade Stone Stop and a few other bits no to mention a full gasket kit. I didn't go as far as installig my Factory oil cooler kit yet I will do that the next time when I install a LSD and replace 2nd gear I did remove the intake manifold boot It looked like it had holes but actually didn't I will be replacing it in the near future I found it new for $65 While I removed the manifold boot I cleaned the inside of the AFM as well as the manifold butterfly it self. but now I have a much Bigger list to do: I purchased a few more items for my project: 915 Shifter Bushing (white cup) Through out bearing kit Flywheel bolts Pressure plate bolts FR5DTC Super Bosch Spark plugs for the Euro engine Fuel filter Projects to d: DONE Repack Axles DONE Scotch bright flywheel DONEAdd Rebel Racing engine mounts DONE Modify current Cabriolet mount project----> http://forums.pelicanparts.com/porsche-911-technical-forum/695601-can-i-modify-3-2-carrera-cabriolet-engine-mount-solid-type.html Cut Air box to Cup/Porsche motorsport Specs Repaint transmission mount and who knows what else wish me luck |
The drive train is about to go in!
Tonight would have been the night it went in, but due to other projects that didn't happen. I manage to: 1. install new Spark plugs (old ones didn't look too bad) 2. Modify Cabriolet engine mount 3. Clean, Sand/Grind Flywheel and Pressure plate 4. Install new through out bearing kit 5. Bolt on transmission to Engine http://i60.photobucket.com/albums/h3...C/6bf1f855.jpg Cabrio Engine mount before http://i60.photobucket.com/albums/h3...C/1c4a11f7.jpg Cabrio engine mount after http://i60.photobucket.com/albums/h3...C/c7cacb70.jpg This is the T/O bearing being removed... Turns out the previous mechanic who I paid to do the work while I was off doing something else installed the bearing wrong ...pretty much destroying the bearing after 1000 miles or less The new one went in Great! http://i60.photobucket.com/albums/h3...C/e0d709f9.jpg This was like the Scene where Pacman meets Miss Pacman the starter was test fitted but will be replaced with a newer one http://i60.photobucket.com/albums/h3...C/d3873742.jpg More Cleaning will soon follow as well as further inspections I will be replacing more Lines and questionable items I wish I could have just take apart the complete intake and cleaned it to look brand spankin new....but not enough time this round http://i60.photobucket.com/albums/h3...C/fb48ab03.jpg http://i60.photobucket.com/albums/h3...C/2247da75.jpg So further inspection let me to this Spark plug car!!! I had just replaced this cap 1000 miles or so It was brand new with a rotor, I couldn't believe it Obviously trash now http://i60.photobucket.com/albums/h3...C/a3864ce1.jpg So the list of projects continues: DONE Modify Air box to Porsche Motor sport specs DONE Add new Rotor and Cap (change of plans) Replace starter (for fun ?) DONE Add Rebel racing engine/transmission mounts DONE Add Carrera Exhaust DONE Replace Fuel Filter DONE Replace Rear shocks DONE Repack Axles Who knows what else I'm going to find before I have to bolt in the engine. I really wish I didn't sell my Carrera Oil tank I need one now The thing is this isn't a restoration project but rather trying to get the car back together as quickly as possible so I can drive it....Currently my daily drive. Borrowing cars, getting dropped off and riding my motorcycle is not my Idea of a fun time. I'm gathering as much information and possible so I can do more engine replacement parts the next time around when I do my LSD and light weight flywheel. Any suggestions or Tips before I bolt it back on would be great SmileWavy |
I don't see it in your photo, so I suggest picking up a distributor dust shield. It would help keep crap out of the distributor springs and flyweights.
P/N 930-602-909-00 http://www.pelicanparts.com/catalog/...ion/9-1-10.jpg |
I would recommend checking for play in the distributor shaft. It could have worn bushings or a missing phenolic washer. Also make sure the weights are moving freely. DME controls timing, but it still uses weights and springs for the rotor phasing.
GTC YES! you are right, I don't have that part in my Distributor
Thank you for the tip, I would have over looked it. I already have it on my parts order list. I was messing with the distributor after you mentioned this. Not sure I noticed any play, I mean it does move a hair but nothing that Isn't out of hand. They weights seems to move freely .. a little rusty dirty but other wise ok... I will update with photos and or maybe a lil video Todays Update: Not too much got done, I ran out of time and had to call it a early night Booooooooooo Project #1 http://i60.photobucket.com/albums/h3...C/1e7c2719.jpg I did mask the Airbox lid and cut the whole side face off! Forgot to take a pic of the "After" more to come... Good stuff I'm betting the sound of the engine will be awesome... I was told this is good for 4-5hp or so....sounds bogus to me..but I guess when you combine it with other stuff like exhaust mods...ect a little here a little there... I mean why else would shops like Andial/Porsche Motorsport NA do it ? Project #2 http://i60.photobucket.com/albums/h3...C/468d1a1b.jpg The next project was pretty easy I swapped out my factory engine mounts for Rebel Racing engine mounts... A few longer bolts made all the difference Lil Cad platting doesn't hurt either http://i60.photobucket.com/albums/h3...C/fc76417a.jpg Project #3 Last project of the day wasn't even complete, due to running out of time. http://i60.photobucket.com/albums/h3...C/a1e43196.jpg I managed to remove the rear passenger side Bilstein Sport Shock and installed the new Shocks that were Supplied from Rebel Racing... This was pretty easy Allen tool to hold it 17mm ratchet wrench to remove and a 22mm break bar/ ratchet. I will do the other side shortly Photos of the shocks installed are coming So not much got done today but looking forward to finishing the project... yet I found more stuff to do today!!! ughh my list keeps growing |
Finally Monday brought more work over to my SC
Worked from 6 to 11pm with a little pizza break in between I finished installing the new rear Bilstein Sport shocks, I was told my old shocks looked like and felt like they were still good. Previous owner told me he had just replaced them...should have believed him ! Replaced the Fuel Filter Replaced the Oil filter both Mahle Added fluid to the transmission did not go with Swepco (even though I had an extra bottle) instead I used Coastal 75/90 it came highly recommended by my mechanic friend who helped me with the transmission rebuild he has won many races with it and swears by it. He said he would kick my ass if he found swepco in my trans again. Installed the pretty Rebel Racing transmission mounts to the freshly painted Transmission metal cross member mount Once again I had some trouble installing the Rebel Racing trans mounts They really require bigger bolts other wise they will not thread all the way. This is something pretty obvious when looking at OEM mounts. A few quick bolts solved that problem. http://i60.photobucket.com/albums/h3...C/66768996.jpg Trans mounts installed http://i60.photobucket.com/albums/h3...C/0b574425.jpg Check out the fresh bilsteins I cleaned the engine bits as best as I could. http://i60.photobucket.com/albums/h3...C/3c813184.jpg Axles still need to be rebuilt before I can really bolt them on... they look a little dirty to me. http://i60.photobucket.com/albums/h3...C/655b60a8.jpg The bottom of the engine got a little oily from cleaning.. I think I need to wipe it down. Luckily my engine has not once dripped oil on the drive way...hope it stays that way. So hopefully tomorrow is the last day I work on the Car for the next month or so. I need to save up more cash. This project has really drained me...ughhh There is sooo much more to do Left to do: DONE Install Bosch Distributor cap DONEBosch Distributor Rotor (still waiting) Install Distributor dust shield DONE Clean Distributor DONE Install Cup style modified Airbox cover DONE connect Fuel lines, Oil lines DONE connect electrical cables DONE I can NOT find the wire for the reverse light! It must have gotten stuck somewhere ughhh!!!! DONE Install new transmission shift cup (white) DONE Instal shift shaft Bushing DONE Instal/Adjust stompski coupler (change of plans) Rebuild Axles (change of plans) Install Cleaned Carrera oil cooler DONE Install Carrera Muffler DONE Add engine oil Castrol GTX (left to do) Maybe tighten up fan belt again (replaced not too long ago) More to come </center> |
| All times are GMT -8. The time now is 03:14 PM. |
