Senior Member
Superman's Avatar
Exhaust Stud Trim
With luck I will be installing the backdated exhaust in the next two days. I plan to not replace exhaust studs and I hope to avoid cutting the existing ones down. The backdated exhaust flanges are thinner, so I plan to use several steel washers under each small barrel nut. In this way, I can reinstall the old exhaust system if necessary.
Is this possible?
Mocha 1978 911SC. "Coco"
Old 05-23-2002, 08:51 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I just removed my heat exchangers...i noticed that the driverside HE's have a different flange thickness than the passengers. Upon further inspection, it turns out that the PO used a slightly larger nut, 5/16 I think, that he used as a spacer. I will most likely use some of these as spacers when i put mine back together. It all looked pretty good before i removed them. it seems that the passenger side HE on my SC has about the same flange thickness as the early style. Or maybe its just mine.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 05-23-2002, 09:45 AM
Senior Member
Supe,
Would really like to see a spacer on each stud rather than a handful of washers to take up the slack. Looks better and bet that it would stay on longer as well.
Tried any parts houses for something like this? Completely agree about not pulling the studs... would rather go to the Dentist!
Joe
Old 05-23-2002, 10:29 AM
Senior Member
Superman's Avatar
Thanks for the input. In case anyone knows, what is the precise thickness of the spacers I would need? Precision is somewhat important because of the design of those small barrel nuts.
I have another question: Metal exhaust gaskets are different on one side than the other. The big hole has a seam around it where the metal wraps around. The seam is not on the other side. Should I install so that the seam faces any particular direction?
Old 05-23-2002, 11:32 AM
find a length of steel tube and cut 12 spacers out of it. on the space shuttle, the seam might blow open if exhaust got under the lip, but not on a 911. so either way works. use the gaskets that have a squishable liner, rather than the all metal liner which tends to not compress.
206 637 4071
Old 05-23-2002, 11:38 AM
Information Junky
island911's Avatar
From a previous post (SSI Superstars)
The difference between thick and thin is big. The thin are about .275" & the thick are .825 thick (about 1/4" & 3/4" for the decimally impaired)
Sheese, a veteran like you, super, not searching thi SSI clinic threads
. . .and you were there
Old 05-23-2002, 12:15 PM
Senior Member
Island911,
Just how many sets of SSI's do you have sitting around the garage?
Got any extra that are just in your way and want to give away??
Joe
Old 05-23-2002, 12:30 PM
Senior Member
Superman's Avatar
I believe I got the exhaust gaskets at a place called John Walker's Workshop. I'll take my chances with their quality. They are all-silver, but they are a sandwich design. I guess it does not matter which side faces the head. I know that a leak will not cause millions of gallons of liquid oxygen to explode several miles above the earth, but I have BTDT with exhaust leaks and I prefer they don't.
The pipe slicing idea sounds like a good one.
Old 05-23-2002, 01:54 PM
