HELP - how do you remove these mounting studs?
I tried a double nut and a razor under the snubber.
I want to keep them intact so I can easily convert back to blown heat in the winter. thanks Bill K http://forums.pelicanparts.com/uploa...1344860072.jpg |
R&r
Grab the lower metal flange with a channel lock type plier and it will come loose, working through the rubber will usually rip it in half.
Mike Bruns |
good morning
thanks Mike - I'll try that tonight. Bill K |
| All times are GMT -8. The time now is 06:00 AM. |
